B3 3.2 Touring its suddenly getting old
Demlotcrew
Post Sun Dec 07, 2014 11:17 am
You can buy sport cats on their own for a low price, anyone who can weld would be able to fit them, just go for a high flow option.
Something like this http://pages.ebay.com/link/?nav=item.vi ... 1265103842
Kos
Post Sun Dec 07, 2014 11:26 am
The turd should run clean enough to pass an MOT without cats.
Fitting the the other exhaust is an option but as the X pipe is in a completely different place it may have some sort of effect on it
The other option would be to use the cats from it and put them into the correct exhaust ?? Probably more aggro than what it's worth
www.pukardesigns.com
IG Pukar.Designs
maxfield
Post Sun Dec 07, 2014 11:28 am
Kos wrote:The turd should run clean enough to pass an MOT without cats.
But it's still a fail if there is no cat there.
Post Sun Dec 07, 2014 11:29 am
they're alot smaller than whats fitted, but i guess its not a bad idea on the whole. I'm probably losing a bit of power because the OE cats are dying/dead anyhow.
I'd rather keep the 3.0 system complete tbh. I could recoup costs of new sport cats with the scrap value of the old ones. I expect they'd get me a good return from the scrapman?!
maxfield
Post Sun Dec 07, 2014 11:39 am
I sold 2 cats off an E36 320 last year for £100, that was to a 'scrap man' in a transit. Couldn't tell you what they're actually worth if you took them to a metals yard.
Kos
Post Sun Dec 07, 2014 11:45 am
Friendly MOT FTW
On a serious note, I wouldn't want to butcher the 3.0's system either simon. I think gutting the OEM cats is the way forward or replace them with some others
as for old cats value, I flogged a pair of cats from my 330i for £60
IG Pukar.Designs
Post Sun Dec 07, 2014 1:01 pm
Well you can see from the pictures that they're big boy cats and 90's BMW cats are well known for getting juicy prices from the scrap man so i've heard
These engines run clean enough to pass emissions on the MOT without cats though?
Kos
Post Sun Dec 07, 2014 1:34 pm
They should do
As is said, my 330i is clean and I've binned the pre cats in from the manifold
I know of 328i e36's that pass emissions without cats. As long as the MAF & Lambdas are in good order you should be ok
IG Pukar.Designs
Post Sun Dec 07, 2014 1:37 pm
well one lambda i replaced not long ago and the MAF is new
Kos
Post Sun Dec 07, 2014 1:38 pm
Happy days
Just cut them out for now
IG Pukar.Designs
BenHar
Post Sun Dec 07, 2014 1:49 pm
Simon13 wrote:Heres another annoying fault, one of my cats is rattling its arse off so what to do? I can forgive it given the milege
I've got a spare alpina exhuast system but its off an earlier 3.0 litre car. Its main difference is at the front with it X pipe design. They're both the same bore size pipework and i'd wager the cats and rear silencers are the same also.
I'd like to think i can just swap the systems over and it won't make much difference?
I think I can see one lamda sensor after the crossflow on the system on the right.
Where is/are the sensor/s on the other system?
Might make a difference to whether it is a straight swap or not.
I think you should just get some new cats welded in.
Ben
Post Sun Dec 07, 2014 3:04 pm
Thats because the 3.0 is Bosch/M50 management and only uses one lambda
The 3.2 is Siemens and uses 2 sensors in the manifolds
Fck welding new cats in, mine would not have a problem with the emissions if it was tested on the later regs, and its easy to trick the machine if need be. If the testers a jobsworth tell him the cat is the small middle box
Post Sun Apr 19, 2015 11:16 am
turned out to be casings around the centre cats rattling not the cats being fubared.
I'm thinking of letting this go to fund a work van now if anyone might be interested
oguz327
Captain Armco
Captain Armco
Post Sat Apr 25, 2015 10:17 pm
Simon13 wrote:turned out to be casings around the centre cats rattling not the cats being fubared.
Kos?
Kos
Post Sat Apr 25, 2015 11:04 pm
I don't think Simon likes me anymore
But he may like my money of the price is right
IG Pukar.Designs
anothere21323i
Post Sat Apr 25, 2015 11:19 pm
What have you got in mind Si?
oguz327
Captain Armco
Captain Armco
Post Sun Apr 26, 2015 12:12 am
Kos wrote:I don't think Simon likes me anymore
if the price is right I am sure you could make him like you again :)
brettski
Post Sun Apr 26, 2015 11:34 am
He has changed his mind :cry:
Post Sun Apr 26, 2015 7:14 pm
Change of heart sorry folks
Post Sun Apr 26, 2015 9:18 pm
You tease!
anothere21323i
Post Sun Apr 26, 2015 10:59 pm
Simon13 wrote:Change of heart sorry folks
You know where that engine and box truly belongs Si...... winkeye
