clutch pedal stuck to floor ??
si911t
Post Wed Apr 01, 2015 11:29 pm
My clutch pedal on sport has decided to stay on floor!
Pressed it in to start and it won't pop back up.
Could it be as simple as a cable needs putting back in place ? Didn't have a torch to hand couldn't check as in garage can't open drivers door fully to have proper look
Thanks for any help /advice
maxfield
Post Wed Apr 01, 2015 11:32 pm
It will be hydraulic related, or possibly something broke on the pedal.
I'd guess at the slave being buggered, it's usually the case. It's always advised to change the slave and master at the same time.
But until you've had a look you won't know.
Post Wed Apr 01, 2015 11:35 pm
First thing to do is open the bonnet and check if there's any fluid in the reservoir.
si911t
Post Thu Apr 02, 2015 7:42 am
Thanks will check for fluid 1st
Carmo13
Post Fri Apr 03, 2015 3:05 pm
Slave cylinder I reckon
