m42-----S38-----2JZ big single
Karan
Post Sun Jul 03, 2005 4:38 pm
Toby_Unna wrote:
Karan wrote:ure gonna have to bodge that up quite a bit methinks
cheers karan i'm good at bodging stuff :rolleyes:
it's gonna sound good though i hope. not expecting much more power as the rest's stock apart from filter and zaust
yeh 6 branch would sound awesome on an m30 cos they sound tasty on m20s as it is
Toby_Unna
Boost Junkie
Post Sun Jul 03, 2005 4:53 pm
if it don't fit i'll just buy a lhd shell instead and put everything on that!
i'd actually like a LHD, it would mean i could turbo it relatively easily in the future. if i bashed mine then that't what i'd get, a lhd shell
Post Sun Jul 03, 2005 4:55 pm
that manifold is well spunky looks just like andy335's?!
Karan
Post Sun Jul 03, 2005 4:59 pm
demlot that h35 had an e28 m5 lump which has a tiny plenum compared to an e34 m5 lump
Toby_Unna
Boost Junkie
Post Sun Jul 03, 2005 5:06 pm
ah he meant h thirty 5
that makes more sense i was wondering what a h25 had to do with it! sorry demlot understand now
Karan
Post Sun Jul 03, 2005 5:08 pm
Toby_Unna wrote:ah he meant h thirty 5
yeh this dude had a real h35-24 at aces cafe
Pete also brought along a customers e34 m5 conversion tourer.. a car that ive seen before... but the conversion standards were interesting
Toby_Unna
Boost Junkie
Post Sun Jul 03, 2005 5:09 pm
serious sh1t!
better come next time! except looks like i might get a bit outclassed
Andy335Touring
Post Mon Jul 04, 2005 5:58 pm
Looking good dude !!! :cool:
I'd go for the smaller servo and leave the plenum alone,fit poly engine mounts from Ireland Engineering in the US and you should be laughing.
The only time mine catches now is if the engine doesn't catch properly on start up and if i piss about spinning my wheels.
I want to get the Golf GTI servo and use the E28 M535 off set engine mounts on mine to move the engine slightly to the passenger side so i've got more clearance between the down pipe and the steering coupling,the only problem is that the mounts are thicker than the M20 ones.
I don't think the standard M20 mounts are strong enough.
Karan
Post Mon Jul 04, 2005 6:01 pm
yeh im running stock m20 mounts..... they do appear softer and i know the e28 m5 ones are a hardser rubber. but yeh they do raise the lump quite a bit!
ill get the poly mounts then i reckon if the engine does swing arounf
gold servo it is then :D
Andy335Touring
Post Mon Jul 04, 2005 6:06 pm
Some good typos there mate :thumb:
Karan
Post Mon Jul 04, 2005 6:12 pm
LOL
im gonna get a 'gold' servo apparently
ive been drinking a lot of coffee to revise i think that would explain the frantic typing
Demlotcrew
Post Mon Jul 04, 2005 6:28 pm
I would hate to say i told you so!
But i will! SO Listen to me, i seen both cars and the H35 had a sponge between the inlet and booster, it was cut and a plate welded in just like pacers touring. An inch is only 2.5cm and thats not allot when you look at the movement of the engine.
A
Toby_Unna
Boost Junkie
Post Mon Jul 04, 2005 6:29 pm
coffee rocks :cool:
sorry i couldn't stick around the other night andy, would have been good to have a chat!
been painting my wheels today will get some pics and a poll up later on, if it stops raining so i can wash it :x
still not replaced that rubber donut yet :nono: i should know better by now, it's blatantly going to come to pieces when i go out in it later
Karan
Post Mon Jul 04, 2005 6:31 pm
Demlotcrew wrote:I would hate to say i told you so!
A
ok i'll put a golf one on which is a bit smaller and grind that down a bit
id hate to hear YOU telling me 'i told you so'!!! LOL
in the excitement i forgot to look at the brakes on the a-trim tourer,,,
also i aint cutting the plenum...... dont wanna lose the effects of the intake resonance flap - ooo-eeer missus :P
Demlotcrew
Post Mon Jul 04, 2005 6:32 pm
it was only cut to the fold. Cant explain it. But the flap was not affected.
A
Karan
Post Mon Jul 04, 2005 6:52 pm
Demlotcrew wrote:it was only cut to the fold. Cant explain it. But the flap was not affected.
A
yeh i know how u mean actually
its a bit silly though when i can just whack a golf servo in
Andy335Touring
Post Fri Sep 02, 2005 10:07 pm
bump :)
Karan
Post Sat Sep 03, 2005 1:19 pm
errrrrrrrrrrrrrrm..... unforeseen circumstances mean not much happened this summer.... and im back at uni now.... engine is in and aligned though...just little things to do now...
Eddy
Post Wed Jan 25, 2006 11:16 pm
So Karan U rollin yet? :D
Building my ultimate drift E30....
Kedge
Post Thu Jan 26, 2006 12:13 am
Good question there Eddy was just wondering about this the other day!
Hows it looking Karan?
Instagram - Kedge85
Karan
Post Thu Jan 26, 2006 1:32 pm
just needs a rad, manifold and exhaust made for it.... should be done in summer
jaistanley
Post Thu Jan 26, 2006 2:00 pm
I was gonna ask the same thing. Sent you a text after new yearsasking how it was..
What brakes are you going for under the 15"s?
I got some for the same reason as you - street sleeper look - but worry about getting big enough brakes under them. The 280's I have are OK but not good enough I fear. Considering 5 series 302mm*28mm disks and calipers (or just caliper carriers if this is possible) with fast road disks and pads.
Also: Do you still have the M5 disks? I beleive they are 315mm*28mm which is the same as an e36 M3 but have a lower hat to disk offset (which is what I need measuring). The reason I ask is that I have some M Roadster calipers that bolt to my hubs but require the inner E36 to E30 M3 spacer adapters to use the M3 disks. I'm wondering if I can fit these calipers and the disks from an M5. Obviously I'd need bigger wheels (bummer) but I'd like to know my options with the stuff I already have.
Many thanks dude and good luck finishing this project!
Hopefully see you Monday at ACE.
Jai
Karan
Post Thu Jan 26, 2006 5:35 pm
i have recently acquired 16in hartge m3 wheels... and i have e34 m5 setup so i may eventually put those on
ure proj looks cool jai prob be done quicker than mine
cya Aces!!!
DieselMeister
Post Fri Jan 27, 2006 2:47 pm
Nice work gents :)
Karan - I take it you're studying for a Bachelor's Degree in Racecraft and Showmanship? 8)
Karan
Post Fri Jan 27, 2006 8:13 pm
no... dentistry actually....
really only ever wanted to do something with cars though,,,,,
DieselMeister
Post Fri Jan 27, 2006 8:40 pm
Karan wrote:no... dentistry actually....
Well, me too.
And I studied law :oops:
Karan
Post Fri Apr 14, 2006 8:12 pm
finally done some work on the car
grbox mount made and fitted and set to correct height to align prop.
measurements for rad and prop done, to be made next week
after that ooff to hayward and scott for manifold and system
not long to go
Andy335Touring
Post Fri Apr 14, 2006 8:42 pm
Cool ! Be nice to see this beasty done ! :cool:
glenn
Engine Transplant Services
Post Fri Apr 14, 2006 10:17 pm
i was wondering how you was getting on with this karan.
i might give you a bell in the coming weeks mate as i've got a S38B38 to do next
Karan
Post Fri Apr 14, 2006 10:21 pm
i will have to pop down ures again glenn some time soon to see wot ure up to.
by the way an ideas on this... http://www.e30zone.co.uk/modules.php?na ... ic&t=32999
cheers
Karan
Karan
Post Fri Apr 14, 2006 10:23 pm
could someone please move this to the engine swaps section as this thread was made before this section existed which shows how long it is taking!!
Simon
Post Fri Apr 14, 2006 10:32 pm
Karan wrote:could someone please move this to the engine swaps section as this thread was made before this section existed which shows how long it is taking!!
Done, be nice to see this done finally!
Karan
Post Fri Apr 14, 2006 10:43 pm
cheers Si
tim_s
Post Fri Apr 14, 2006 11:16 pm
can't wait to see this mate. :cool:
is going to be nuts
you'll have to scare the shit out of me (again! and get jonb screaming like a girl) in it once its finished...
2.1 318is, MS, LPG. 200bhp, 175ft/lbs GONE!
Boxster, e46 m3, e36 sport touring and alpina B3 3.0
Eddy
Post Sun Apr 16, 2006 2:11 pm
I try to imagine how this car is gonna go,It`s gonna be wild!! 8) 8)
