mercdriver
Post Wed Mar 04, 2015 8:05 pm
**this should of been written yesterday**
BROKE IT winkeye
Gearbox fail - stuck in reverse
No worries though, I still got in to work without it in my e60 :eek:
I'll check with the manager
RetroAde
Post Wed Mar 04, 2015 9:43 pm
Quick interior valet and fed the bejeezus out of the leather.
Then out for a quick spin in the sun.
RetroAde
Post Wed Mar 04, 2015 9:46 pm
Quick stop in the sticks for a few photos.
Robbo-80
Post Thu Mar 05, 2015 4:34 pm
Took advantage of rare sunshine in Scotland & treated her to abit of spit 'n' polish 8)
jimbom30cab
Tech 1 freak
Post Thu Mar 05, 2015 4:39 pm
Are you bringing it to Holland Steve, looks fab!
Robbo-80
Post Thu Mar 05, 2015 4:41 pm
jimbom30cab wrote:Are you bringing it to Holland Steve, looks fab!
Yeah that's the plan Jim, probably need a good wash 'n' polish after the drive down to Folkstone :mad:
jimbom30cab
Tech 1 freak
Post Thu Mar 05, 2015 4:58 pm
Cool
hennabm
Post Sat Mar 07, 2015 7:16 pm
Checked the 320 over today for service etc and found the NSF factory pad missing. No big deal so far -
but it has left a huge hole behind it caused by the dreaded tin worm. :cry:
Looks like I need a welder :roll:
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
BHadley
Post Sat Mar 07, 2015 7:22 pm
I know that feeling.... " oh that looks a bit soft..... Push with thumb and voila hole appears! "
I repainted the crap pattern wing I bought as it went rusty in weird places!
Just flatting and polish to do tommorow ... Mostly on the big run I got in the laquer!! Grrrr. !!
Post Sat Mar 07, 2015 8:02 pm
Charged the battery, washed it, put it in the other side of the garage. Made a massive to-do list.
Cypriotgeeza
Post Sun Mar 08, 2015 10:21 am
Polished her and took her for a bit of topless fun winkeye lol
Plenty more pics in my project thread if anyone is interested :D
Check my M30 build threads:
joeyb
Post Sun Mar 08, 2015 11:38 am
Put a battery on it, filled up the PAS fluid, added water and antifreeze.....then started it for the first time in over a year!
MOT booked for next weekend. Need to buy some tyres and a replaces HID bulb as one has died.
Post Sun Mar 08, 2015 12:04 pm
haven't seen this car for 3 years pulled the cover off couldn't be ar5ed, so put cover back on :)
Cypriotgeeza
Post Sun Mar 08, 2015 12:08 pm
e30topless wrote:haven't seen this car for 3 years pulled the cover off couldn't be ar5ed, so put cover back on :)
:chuckle: I've had so many of them days! Just stand there staring at it thinking of all the stuff you have to do..
then decide you'll do it another day lol
RetroAde
Post Thu Mar 12, 2015 9:53 pm
Quick clean up in the engine bay
RetroAde
Post Thu Mar 12, 2015 9:55 pm
Degrease, clay, polish, wash, wax = shiny.
oomz1975
Post Sat Mar 14, 2015 12:38 pm
Passed MOT with no advisories, happy days. :D
Post Sat Mar 21, 2015 5:44 pm
Replaced in tank fuel pump. Happy that old one was clearly fooooked as the new one is virtually silent in comparison and starting is improved too.
Removed the glovebox trim in order to tidy up the stereo wiring so the stereo now sits flush with the dash rather than about 5mm out and loose like it has been for as long as I can remember - it's been bugging me for ages :D
Post Sat Mar 21, 2015 8:03 pm
capri_rob wrote: the stereo now sits flush with the dash rather than about 5mm out and loose like it has been for as long as I can remember - it's been bugging me for ages :D
Not just a matter of aesthetics - I've come across wiring that has been cut into and short circuits caused by wiring not dressed properly behind the stereo, and crushed between the metal corners of it and the bracket behind.
polsta
Post Thu Mar 26, 2015 6:44 pm
Big thanks to GAVLAR , I fitted this today to go with the new coolant hoses and tank, been blasted painted baked by gav, I got new bolts,washers,sensor,washers, gasket, bleed screw from Bmw for £10 , popped it in and it looks a million dollars, cheers gav and I recomend his services
Just need to sort the corroded bracket above it now
**BANNED**
Post Thu Mar 26, 2015 7:44 pm
The FPR looks a bit scruffy as well!
winkeye
Youth is wasted on the young.
polsta
Post Thu Mar 26, 2015 8:34 pm
I know,I'm getting round to that, it's bracket , as mentioned above - does that just come off ? Il have a look at it tomorrow
**BANNED**
Post Thu Mar 26, 2015 8:41 pm
polsta wrote:I know,I'm getting round to that, it's bracket , as mentioned above - does that just come off ? Il have a look at it tomorrow
Yes,those two scruffy 10mm(?) bolts will release the FPR and it's bracket.
FPR will most likely clean up with a bit of elbow grease.
Be aware that you will spill petrol when playing with the FPR!
polsta
Post Thu Mar 26, 2015 9:30 pm
Ok thanks il have a fiddle tomorrow , does the bracket I presume then remove from the fpr ? Can I leave it connected and then remove the bracket to clean up and not spill fuel ?
Been doing a lot of bay bits, il post a thread once finished, picking up a newly painted rocker and inlet tomorrow
BHadley
Post Thu Mar 26, 2015 9:55 pm
Bled brakes ..... Doodle with gunsond ezzibleed
Knocked off the surface rust on the discs
Gave it a wash
Moved to new garage near my house, first time it turned a wheel for a year or so.
Just rustproof the front end to do..... And then the back end repairs ...
Post Tue Mar 31, 2015 7:53 am
Taxed it - from tomorrow :cool:
darkchild
Post Tue Mar 31, 2015 10:29 pm
Winter Bottletops off, summer BBS on. :)
BHadley
Post Tue Mar 31, 2015 10:33 pm
Polished the turd, came up very well !
Dug out some parts for it from the back of the shed...
Post Thu Apr 02, 2015 6:28 pm
Painted the front grilles and popped on another kidney grille and de-yellowed the lights.
Looks lovely.
It will look even better when the paint ( Diamond Swaaaaaaaaaaarthhzzz) has all the winter crap taken away.
316 Baur.
Post Fri Apr 03, 2015 9:29 am
Drove it to work and back yesterday. Found that the fuel pump I fitted a few weeks ago has made a nice difference to how it starts.
Unfortunately the speedo stopped working as the wire to the sender has broken again - I think the wire has gone brittle as when I tried to strip it back and join it the core was not shiny as you would expect but heavily tarnished.
Think I need to chase it back to where it's good wire and then put a new section in.
Post Fri Apr 03, 2015 10:04 am
capri_rob wrote: I think the wire has gone brittle.........
You are quite correct. The wire has become brittle as a result of vibration from the diff., and the only way to restore it is to heat it up until it glows red, then let it slowly cool - a bit impractical, since the wire is covered in PVC insulation.
If it can't be restored, then it needs to be replaced, at least back to where it hasn't been subjected to vibration, which means at least 300mm. A suitable length of wire, complete with the correct plug, can be found on the headlamps of facelift E30s.
Cheekychunkyfunkymonkey
Post Fri Apr 03, 2015 11:24 am
Just been in for MOT, flown through, no advisories.
WAHEY :banana:
Got the proverbial ripped out of me for only doing 102 mile in it since last year though :o:
The owner of one of the last registered e30 tourers in the UK. If not the last registered!
94 316i lux tourer( Life's too short without one)
Post Fri Apr 03, 2015 3:33 pm
Already got the plug and probably more than 30cm of wire on it thanks to danthe just not got round to doing it yet.
In terms of sorting it does this wire come from inside the car out to the diff - i.e can I pull it back through into the rear seat area, do the repair inside the car rather than scrabbling around with a soldering iron underneath and then pull it back through ?
Post Fri Apr 03, 2015 6:52 pm
The wire connects to the plug that should be cable tied to the steel tube on the rear seat pan that contains the fuel tank vent pipes, and there's no reason why you shouldn't replace the wire all the way back to here, if it's long enough, other than you will have to make a hole for it in the grommet that feeds the loom through the seat pan.
Alternatively, you can pull the grommet out of the seat pan, as far as it will easily come, then splice the wire to the loom on the bottom side of the grommet, but working inside the car.
polsta
Post Fri Apr 03, 2015 7:03 pm
Having issues with my speedo at mo, garage fixed it yest and a cple of breaks in it, worked and then packed up again after 2 miles ,got a new loom complete with both end plugs to sender and under bench
I was hoping to keep this until rear axle refurb to save chopping it , how long laboue time wise is it to do the whole wire and go back to fuel sender properly instead of splicing ? Is it tank out job ?
