clutch blleding
spiderman
Post Sat Feb 07, 2015 4:02 pm
hi, i've fitted a new clutch master cylinder on my 1985 320i e30, and i am having trouble getting a decent pedal. is there any weird way or sequence of pumps needed to build up the pressure? cheers scott
RobWill116
Post Sat Feb 07, 2015 4:20 pm
You can bleed the clutch with a one-man bleeder kit on the bleed nipple, or just keep pumping the clutch pedal with the lid off the reservoir.
I hope you changed the clutch slave cylinder at the same time, or you'll likely be changing that shortly after when it fails...
Post Sat Feb 07, 2015 8:35 pm
E30 can be very difficult to fill and bleed from dry.
The initial bleeding seems to fill the fluid with microscopic bubble, so leave it for twenty four hours to allow the bubbles to collect together into bigger ones that will come out with normal bleeding.
maxfield
Post Sat Feb 07, 2015 8:42 pm
I've never really had problems bleeding BMW clutches.
But some clutches I've had to back bleed using the brakes.
**BANNED**
Post Sat Feb 07, 2015 8:48 pm
maxfield wrote:I've never really had problems bleeding BMW clutches.
Tell us more....
Youth is wasted on the young.
maxfield
Post Sat Feb 07, 2015 8:54 pm
A pipe from a brake bleed nipple to the slave nipple and pump the brakes.
spiderman
Post Mon Feb 09, 2015 7:46 pm
yes, changed the slave as well, and it just needed a bit of patience, all sorted thanks for the replies. scott
