A hot tip off and a deal was done..... E34 M5 3.6
Jon_Bmw
- Dangerous when thinking
That's just half of it though Barry.
Its the Crank, Pulley, Flywheel, Clutch Cover balancing where the benefits will most likely come from.
Watching a 6 cylinder one whip round is eye watering, as all I can imagine is it coming flying off said balancer!
Guys, I'm well aware of the benifits of balancing the rotating parts and have done on previous builds on engines that are inherently poor to start with such as Ford 4 pot donks but on a hand built S38 that's already pretty well balanced and that is not a modified build and not going to see track use, the costs are simply not worth the gains.
To put it simple, the engine is being built to OE spec, a more noticeable gain would be to lighten the flywheel but even that's not going to happen.
If it were a race engine or heavily modified road engine then there would be no question.
Is that what janspeed charge as the place I use quoted £475 to do the whole bottom end?Jon_Bmw wrote:£100-130 to get it balanced....seems a no brainer.
It is where all the costs add up though, the 'little' bits at a £100 here and a £100 there.
no need for the condescending tone, the benefits far out weigh the cost.
You'll sell this for profit like all of them. I'd wager a balanced bottom end will run drive/nicer compared to a stock engine.
BMW built 1000's of these cars handbuilt or not theres scope for improvement and this isn't a "mod" its what the sensible person would do who is 5 grand into it anyhow and on a full engine rebuild. The place i use charged me £140 for my M20 engine a few years ago. I doubt its anymore than £240 even now.
You've just made £3000 selling wheels and 5 stud setup.
Andyboy
- Alpina Colada
£3000 better kept or spent on something useful! An S38 isn't an M20. When the bits were made they would have been made and balanced to closer tolerances. It took something like 2 days to build these.Simon13 wrote:no need for the condescending tone, the benefits far out weigh the cost.
There will still be scope for improvement. Maybe not so much in the rods pistons but in the balancing of the crank and moving parts there will be.
I genuinely can't believe that you or anyone else on here would argue against it!
Its small change in the grand scale of things
I'm not arguing against the pro's at all, just that it's not necessary to be done with this build and yes ive sold some stuff for decent coin but i have also just had an offer accepted on a bigger house so much money is being sucked up by that!
To even keep this build going to a high standard while all that is going on has been hard enough so to add other costs in that i don't need to is not going to happen.
I'm not replying in a condescending tone, its just some of you are going on like ive never heard of balancing or its benefits.
And yes, it will be sold at some point but i'm going to enjoy it for a while first.
Jon_Bmw
For the crank, pulley, flywheel and clutch cover, yes it would be about £120-130+vat. To balance the pistons and rods would be more.bss325i wrote:Is that what janspeed charge as the place I use quoted £475 to do the whole bottom end?Jon_Bmw wrote:£100-130 to get it balanced....seems a no brainer.
We tend to do it fairly cheaply to get people in the door as they usually do not know we do it + it can lead to other things. Dyno work etc.
BenHar
Straight sixes do not need to be that well balanced. I'm sure the M engine was well enough balanced when it left the factory.
For once Barry is right.
Ben
Ben
Andyboy
- Alpina Colada
Hans "Has that crank, flywheel and front pulley been balanced as best as we can do it on our very expensive machinery".Simon13 wrote:There will still be scope for improvement. Maybe not so much in the rods pistons but in the balancing of the crank and moving parts there will be.
Fritz. "It's not bad but I can't be arsed to spend a hour doing it. I'm going down the pub".
maxfield
Quality!Andyboy wrote:Hans "Has that crank, flywheel and front pulley been balanced as best as we can do it on our very expensive machinery".Simon13 wrote:There will still be scope for improvement. Maybe not so much in the rods pistons but in the balancing of the crank and moving parts there will be.
But probably true.
Just hope it was built mid week Barry, nobody gives a fuck on a Monday or a Friday.
10/7/1990 was a tuesday but these cars took two weeks to build so who knows when the engine was put together and more to the point, is the build date the beginning or the end of that two week period?maxfield wrote:Just hope it was built mid week Barry, nobody gives a **** on a Monday or a Friday.
Thats very close to when I was born.bss325i wrote:10/7/1990 was a tuesday but these cars took two weeks to build so who knows when the engine was put together and more to the point, is the build date the beginning or the end of that two week period?maxfield wrote:Just hope it was built mid week Barry, nobody gives a **** on a Monday or a Friday.
Don't make me feel old Mo!
Kos
you looked young in the ML featurebss325i wrote:Don't make me feel old Mo!
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
EFAKos wrote:you looked fat in the ML featurebss325i wrote:Don't make me feel old Mo!
To be fair to Andrew, it was his feature about servicing.
how many miles has it done ?
I'm doing an M88 at the minute, 29 years old 150k of hard miles and it's all well within tolerance and doesn't need Balancing,
You bought the chain kit yet Baz ?
This turd should be a real nice tram with a fresh Donk
53k and no, the M tax bits are the next cost!
Demlotcrew
I would be tempted to have the crank and fly wheel indipendantly balanced to zero, makes a noticeable difference.
topless your so full of sh!t its shocking sometimes.
I can see you point Barry its not the end of the world just thought you'd be up for that
I most certainly will be up for it on my next build!
so how do you come to that conclusion I would love to know ?Simon13 wrote:topless your so full of ********* its shocking sometimes.
SteSE
- Heading for the Naughty Room
whats gonna happen with this then?
It will be completed in time for Gaydon hopefully!
Well its full steam ahead with this now!!!!
With the M3 out of daily action for the mean time the only working car I have at the moment other that the E46 the mrs mostly uses, is my 325i so instead of spunking money on so other tram, and what with this dragging on it was time to get a move on!
All of the engine parts have now been bought and delivered so today was time to crack on with it.
The crank had the journals polished and was chemically cleaned.
Pistons measured up in spec and had no wear or score marks, these with the rods were also chemically cleaned.
All journals were plasti gauged and were in spec with standard size bearings.
Crank in with new bearings and mains bolts.
Expensive bag of rings!
Pistons, rings and rods assembled.
Slotted in to the freshly honed bores and bolted up to the crank.
New timing chain, guides and oil pump chain fitted.
Timing cover bolted up with the re-plated bolts.
A fairly expensive head gasket. Multi layer steel thicker one from cometic due to the head and block being skimmed.
Head on.
Exhaust studs in and that's it for tonight!
More tomorrow.
Head on.
More tomorrow.
Nice Mill
jimbom30cab
- Tech 1 freak
Love it. Expensive hobby I bet !
Engine porn
hmmm mine leaks oil where your flange sealant is!
Best get your cam carrier off then!
Probably still on the original sealant.
Great more fun in the future its not getting done yet, at least its not quite a full on head off job.
oguz327
- Captain Armco
mmmmmm flange...
Taz
epic engine build
