Heated Seats
nav786
is it possible to buy the heated seat stuff from anywhere? i bet its real expensive... if so is it possible to get one from another Bmw series and fit them to your seats.
FOR SALE
SONY PSP'S £100
Ziggy
I went for an aftermarket kit - Ԛ£40. Included everything & works a treat
It's a must-have in a cab...
Simon
You went for the waeco stuff after?Ziggy wrote:I went for an aftermarket kit - Ԛ£40. Included everything & works a treat
If you want heated seats, go for the kit from waeco, they don't list it on the site, you have to phone them, get the wiring loom and switches from the dealer, and you've got heated seats for less then Ԛ£100.
Dominitry
I want these in sport, i hate the cold with a passion.
Ziggy
I think it was the waeco stuff like you recommended - I got it from eBay in the end though & it was a while ago! I just used their loom & switches too, but I'll get the proper BMW stuff at some point.
I wouldn't want to be without it though - on a cold morning like today I start the car & put the seats on, then when I've de-iced the windscreen they're nice & warm
Can't beat top down motoring on a sunny winters day with the heated seats keeping you toasty too!
Simon
Good stuff, worth getting the loom and switches for the factory look. Loom is Ԛ£30, and I 'think' the switches are about Ԛ£20 each.
Gwynleym10
While were on the subject of heated seats... why is my drivers seat a lot hotter the passenger seat? I think my girlfriend has been waring it out....
Oh yes they are lovely on a cold day, and heat up so quick!
Simon
Are they wired up OK? Did you fit the elements in different parts of the seat? Or like you say, maybe it's overused!!Gwynleym10 wrote:While were on the subject of heated seats... why is my drivers seat a lot hotter the passenger seat? I think my girlfriend has been waring it out....
nav786
any contact details guys, website...phone number.. etc?
had enough of freezin my arse on the leather.
cheers.
cheers.
FOR SALE
SONY PSP'S £100
Simon
gazza
wouldnt mind some in my cab bloody freezing at 5.30 in the morning going to work anyone got any pics ...do you have to strip the seats right down to install....how easy is it to do
nav786
your a star simon
FOR SALE
SONY PSP'S £100
Simon
Yes, you need to remove the centre sections of the seats to install the elements.gazza wrote:wouldnt mind some in my cab bloody freezing at 5.30 in the morning going to work anyone got any pics ...do you have to strip the seats right down to install....how easy is it to do
Wiring loom plugs into the box located above the glovebox, run down the centre console, cut some holes for the switches, and run the remainder of the wiring under the carpet and out in the hole under the seat.
nav786
si, do you use original loom or do you get one with it? and i take it i will also need the relay?
FOR SALE
SONY PSP'S £100
Simon
Personally, I'd buy the loom and switches from the dealer, but you can use the loom and switches that come with the kit if you wanted, no harm there, if you're using the standard loom, I believe they use the same reay as the electric roof..not sure about the cab, easy enough anyway, as apart from the wiring to the switches seats, the rest is already there, plug in a fuse (if there isn't one already fitted) and away you go.nav786 wrote:si, do you use original loom or do you get one with it? and i take it i will also need the relay?
I found a few kits on german e-bay for you so you can see what's included...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 8030861570
http://cgi.ebay.co.uk/Waeco-Sitzheizung ... dZViewItem
JAMZ
Either way.... hurry up Nav...
Soon as yer done i expect pictures and then il come up to yer with some coffee in hand so you can do mine too..
nav786
thankyou once again si, i think i'l go for the original loom and switch, one thing do you know if the swithces are the same on other models such as the 635csi.
FOR SALE
SONY PSP'S £100
A1BMW325iSport
heated seat kits come up on ebay.de every so often
Relay is K5, fuse is 16, and socket on the accessories panel is U, which is on the top row, 2nd from the right, just to the right of the 4 pin radio plug. Only problem that you might have, is that not all E30s have the brown/white wire from fuse 16 to the accesories socket fitted.nav786 wrote:si, do you use original loom or do you get one with it? and i take it i will also need the relay?
If fuse 16 has an outer terminal fitted, then the wire is there.
eun
seems like a good mod
i didnt know it would be this cheap though.
summat that i could try on a sunday when im
doing nothing
doing nothing
bootyman
Ho poo. I was getting all excited there until i read about the centre consol and running wiring under the carpet bit. My seats are welded down so arent going nowhere. With everything trimmed, i cant just start cutting holes either. Ho well. Just as well i have my thermal underwear to keep me warm then
Kedge
Something i've been considering since i got my leather seat, never expected it to be so cheap, i thought the switches were ment to be about Ԛ£70 on there own.
A1BMW325iSport
switches are 34quid each i think
Demlotcrew
All the wiring should run down the left hand side of the car under the carpet, with the rest of the wiring looms.Simon wrote:Yes, you need to remove the centre sections of the seats to install the elements.gazza wrote:wouldnt mind some in my cab bloody freezing at 5.30 in the morning going to work anyone got any pics ...do you have to strip the seats right down to install....how easy is it to do
Andrew
Simon
Demlotcrew wrote:All the wiring should run down the left hand side of the car under the carpet, with the rest of the wiring looms.Simon wrote:Yes, you need to remove the centre sections of the seats to install the elements.gazza wrote:wouldnt mind some in my cab bloody freezing at 5.30 in the morning going to work anyone got any pics ...do you have to strip the seats right down to install....how easy is it to do
Andrew
It doesn't matter where it goes, I just went for the easiest route, which is down the centre console, lots more room too.
Gwynleym10
Ah I was wondering why the wiring was waaay to long.All the wiring should run down the left hand side of the car under the carpet, with the rest of the wiring looms.
Andrew
i have never touched the elements and all the wiring is intacked.Gwynleym10 wrote:
Its not to hard to get at the elements is it? They might be dirty or positioned badly or something...
