Bulletproof E39 shooting break
Post Fri Jan 02, 2015 3:59 pm
It's a shame it hasn't got the Manual 6 speed for a quicker getaway :D
:eek:
http://www.ebay.co.uk/itm/301469233413? ... 26_rdc%3D1
Andy325i
Post Fri Jan 02, 2015 4:58 pm
Interesting, but how many spelling errors can you get in one advert? And is it just armoured glass or bullet proof body panels as well?
Interesting never the less :-)
Topblag
Post Fri Jan 02, 2015 4:59 pm
Tempted. I do enjoy a shooting break and don't mind a left hooker. The wife did say she would shoot me if I bought another bmw......
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Post Fri Jan 02, 2015 5:20 pm
If I had a pound for every ad where some peasant with an E38 / E39 with double glazing reckoned his turd was 'armoured' / bullet proof, I would be rich :(
Proper armoured turdz are very different to standard cars and that turd is definitely NOT armoured.
gooner1
Out humping Reindeer
Post Fri Jan 02, 2015 5:33 pm
Obviously not Pete, cos you've just shot it to pieces.
Post Fri Jan 02, 2015 11:41 pm
There are lots of E39's that have "armour prepared" on the build sheet, this does not mean it is bullet proof or that it has any more protection than a standard E39, there are also lots of E39's that have double glazing, again, dont throw stones/pop caps etc :D
Bodged up polish turd, and thats about it.
Post Fri Jan 02, 2015 11:45 pm
pacerpete wrote:If I had a pound for every ad where some peasant with an E38 / E39 with double glazing reckoned his turd was 'armoured' / bullet proof, I would be rich :(
I knew you would be the first to spot that ! :wink:
zd3bx
Never understood people who bought a car with a big engine and then put LPG on it :?
Buy a Micra, if you can't afford the petrol, but don't ruin a 540i...
Post Fri Jan 02, 2015 11:48 pm
zd3bx wrote:Never understood people who bought a car with a big engine and then put LPG on it :?
Ha! Ridiculous statement of the year award early entry :D
Post Fri Jan 02, 2015 11:49 pm
so you have never run a 540i as a daily then ? :)
Post Fri Jan 02, 2015 11:53 pm
LPG is great IF it is done PROPERLY unlike the Polski sklep in the back of that '39 :eek:
bab-91
Post Sat Jan 03, 2015 12:00 am
I'd defiantly fit LPG to an 'offender' or Range Rover.
IG - bab91
Post Sat Jan 03, 2015 12:21 am
LPG is the fuel you need to be using if you want an engine to last. A far more suitable fuel for a spark ignition engine than petrol.
Post Sat Jan 03, 2015 9:19 am
This is much more fitting for the up and coming gangstar innit
http://www.ebay.co.uk/itm/BMW-728I-LPG- ... SS:GB:1120
zd3bx
Post Sat Jan 03, 2015 6:10 pm
If LPG is so good, last time I checked there's not a single major manufacturer who sells a car with LPG fitted? There must be quite a few reasons behind that...
Yes, I know, obviously the mpg of the 540i will be monstrous, but that's my point - if you can't afford it, don't buy it :)
maxfield
Post Sat Jan 03, 2015 6:17 pm
zd3bx wrote:If LPG is so good, last time I checked there's not a single major manufacturer who sells a car with LPG fitted? There must be quite a few reasons behind that...
Vauxhall for one. Or they used to.
bab-91
Post Sat Jan 03, 2015 7:06 pm
LPG isn't readily available in all areas.
IG - bab91
zd3bx
Post Sat Jan 03, 2015 8:11 pm
Don't get me wrong, I don't have anything against LPG in general - if you want to use it and it seems like a more appropriate choice (financially) in your position, then go for it...
What I find silly is when LPG is fitted to cars, which are initially thirsty, so buying them for fuel economy is pointless in the first place (if that's what you care about)...
But then fitting them with LPG makes you look like boy racer who can't afford to pay for petrol. Some old AMGs come to mind...
Again, this doesn't apply to commercial vehicles or cars with small'ish engines, which are decent on fuel as standard, so fitting LPG makes sense.
Post Sat Jan 03, 2015 9:06 pm
All spark ignition engines run by igniting a mixture of air and 'gas'. Petrol is not a gas at normal temperature and pressures, so has to be made to simulate a gas for the engine to work.
This requires a high pressure electrically powered pump to transfer the fuel from the tank to injectors, normally mounted as close to the engine inlet valves as possible, which then squirt the fuel under pressure to form a mist - as close to a gas as the petrol is going to get. As soon as the mist is formed, it will start to condense back to a liquid, which doesn't happen a great deal with a hot engine, but when cold, an appreciable amount does condense, washing the oil film off of the cylinder walls and contaminating the oil in the sump.
LPG is stored as a liquid in its tank under considerable pressure, so no pump is required to move it. It's just fed through a pressure reducer, where it turns into a proper gas, with no tendency at all to turn back into a liquid. This gas is then fed to injectors, which are just simple solenoid valves, also mounted close to the inlet valves, but this time only to reduce throttle lag, where it readily mixes with air to form the flammable mixture. No tendency to separate again, no washing of oil from the bores, no oil contamination, and no need to pour in half as much fuel again as is actually required until the engine is hot.
The combustion products of LPG are largely innocuous - no acids contaminating the oil as with petrol. Very little CO produced - a correctly set up engine running on LPG will produce emissions well under the post 08/91 limits without the aid of a power sapping catalytic converter.
I can, and do, happily work on running LPG cars in my workshop with all the doors closed, where, if I tried the same with a petrol (or God forbid, a diesel) car, I would have passed out or have a severe headache in minutes.
Post Sat Jan 03, 2015 10:34 pm
An AK 47 would turn that thing into a tea bag in 3 seconds
Post Sat Jan 03, 2015 11:01 pm
Car manufacturers are in bed with petroleum companies for obvious reasons, when they have a massive population of ignorant car buyers why would they turn them against their big buddies that give out advertising/sponsorship money because they are selling fuel at extortionate prices?
I run a 540i as a daily car, 20k miles per year, why would I pay £100 for 300 miles when I can pay half? Add up the savings, it more than pays for my heavy right foot connected to a 300hp V8 every day :)
What do you drive most days out of interest?
Oh, and just to rub it in winkeye
Post Sat Jan 03, 2015 11:12 pm
Poland are one of the biggest users of LPG for cars, all the parts for my conversion came from there at more or less half the price they cost in this country. Like everything, there are pros and cons, but its there to be taken advantage of IMO.
Post Sat Jan 03, 2015 11:14 pm
Plenty of filling stations in the UK, the only problem is most are pricing it against petrol, rather than the actual cost of the gas
http://www.filllpg.co.uk/index.php?page=lpg.php
Topblag
Post Sat Jan 03, 2015 11:37 pm
I smoke about in a an E34 525ix touring running lpg. It's about 47 mpg equivalent on the lpg, has 4wd, a monster boot and tows things. What's not to like ? I don't understand the anti-lpg stance. Just be sure there are supplies in range. I have one station 3 miles away and another 9 miles away.
Post Sun Jan 04, 2015 10:24 am
As said a million times before its fine if there is an LPG station on your door. There isn't one where i live and if i did have an lpg'd motor i'd have to make a specific trip to fill it to go to a place i never visit otherwise. That would get boring rather quick.
Andyboy
Alpina Colada
Post Sun Jan 04, 2015 10:40 am
Brianmoooore wrote: I can, and do, happily work on running LPG cars in my workshop with all the doors closed, where, if I tried the same with a petrol (or God forbid, a diesel) car, I would have passed out or have a severe headache in minutes.
I actually had carbon monoxide poisoning a few weeks back when I briefly fired up an M535i in the workshop. Ran it for 10-20 seconds, shut it off, job done. Within 10 mins I felt queazy, went outside and keeled over next to a car in the road. Was lying there semi conscious for 5 mins and felt very dizzy and disorientated for 2-3 hours.
Post Sun Jan 04, 2015 3:11 pm
I hear an M30 burns 14 litres of fuel per minute at idle when cold :P
Post Sun Jan 04, 2015 3:14 pm
There is a Maxfield gag there somewhere :)
On a more serious note, I trust you maced the victim for your troubles :D
