changing bushes
matt86
Post Thu Jan 01, 2015 9:44 pm
I'm looking to change all the bushes on my car in the next few weeks and was wondering whether its best to go with genuine bmw, or the likes of powerflex polybushes or similar?
age
Formerly twist316
Post Thu Jan 01, 2015 9:47 pm
euro car parts for oem rubber
M40 rightness if you can get to 6000rpm noone can hear your tappets
Post Thu Jan 01, 2015 9:50 pm
Or BMW, you may be surprised with the prices quoted :)
matt86
Post Thu Jan 01, 2015 9:52 pm
ImysE30 wrote:Or BMW, you may be surprised with the prices quoted :)
Ok thank you. Is there any real benefit of getting aftermarket bushes. Will they all last around the same amount of time and give similar handling characteristics?
Post Thu Jan 01, 2015 11:04 pm
No benefit whatsoever with aftermarket bushes, with the possible exception of the anti roll bar support bushes, and several drawbacks.
Most feel the steering response is improved by fitting OE E30 M3 front control arm bushes, E46 OE rear damper upper mounts are stronger and longer lasting than E30 ones, and the rear anti roll bar links from a 2000 Ford Mondeo estate provide a longer lasting replacement for E30 front roll bar links, for about the same cost.
Your rear trailing arm bushes very probably do not need replacing.
matt86
Post Fri Jan 02, 2015 12:51 am
Brianmoooore wrote:No benefit whatsoever with aftermarket bushes, with the possible exception of the anti roll bar support bushes, and several drawbacks.
Thanks Brian. :D
BHadley
Post Fri Jan 02, 2015 1:09 am
Lemforder and TRW are OE brands and are very well priced on euro car parts.
matt86
Post Fri Jan 02, 2015 1:11 am
slideout318i20 wrote:Lemforder and TRW are OE brands and are very well priced on euro car parts.
Ok thanks :thumb:
