Brake Upgrade Kit ......
sindako
Post Fri Dec 05, 2014 12:13 pm
Mates , What do think ?
Tomorrow i'll take my conversion plates from the forge ,
i am Upgrading the brakes of my e30 ,
Using E32 Calipers , with Auti TT 312mm x 25mm Rotors .
I Guess Now the Car will Have Better Brakes ,
I've seen E30 with EVO6 calipers and rotors , Subaru Calipers and Rotors , Mercedes w124 brakes and rotors .
But those TT 312mm are damn too good , So I am Goin For it ,
Also It's Amazing i don't have to Miss up with my Hub and the 4x100 diameter , just the conversion plates and Some Rotor Redrilling .
Photos Will Be Posted Soon .
Cheers .
clarko74
Post Fri Dec 05, 2014 2:36 pm
I'm just in the process of doing this conversion myself.
With calipers that big you'll probably need a larger master cylinder.
clarko74
sindako
Post Fri Dec 05, 2014 9:02 pm
I've Read about it somewhere online , And The Conversion didn't include any master cylinder replacement , I'll try it on the OE Master Cylinder , If It's Rubbish i'll get an e36 M3 one or maybe a 7 series one .
I'll hit the Realoem to see what cars had the same cylinder as the E30 , if the 7 series had the same then there'll be no problem .
Lurch320i
Post Sat Dec 06, 2014 12:02 pm
You don't want the same master cylinder as the e30 one
You need a bigger bore one with a larger piston inside
Did I comment on your post on Facebook?
Ant
Retired Team Member
Retired Team Member
Post Sat Dec 06, 2014 12:37 pm
7 series E32 master cyl a must have on this I'd suggest
std m/cyl will work but long pedal bigger piston area means the m/cyl needs to displace more fluid per stroke to be an effective upgrade
satan16v
Post Tue Dec 09, 2014 8:22 pm
Do you need to change the brake flexis too?
I'm looking at doing this next year, and have Goodrich hoses at the moment, which I'd like to keep
Its either this or the Porsche 986 set up
But I want to find about the hoses before I commit
E30 325i - In progress
E53 X5 4.6is - SOLD
E46 320d Sport Tourer - SOLD
E36 M3 - SOLD
E34 535I Sport - SOLD
Lurch320i
Post Wed Dec 10, 2014 11:27 pm
My braided hoses fit the bigger a calipers just fine :)
satan16v
Post Thu Dec 11, 2014 6:28 pm
Thanks Lurch
E53 X5 4.6is - SOLD
E36 M3 - SOLD
uvels
Post Wed Dec 17, 2014 11:06 pm
where can i buy that adopters,can i use e38 Brembo callipers??
satan16v
Post Thu Dec 18, 2014 12:22 am
300mm.de
E53 X5 4.6is - SOLD
E36 M3 - SOLD
clarko74
Post Thu Dec 18, 2014 9:47 am
uvels wrote:where can i buy that adopters,can i use e38 Brembo callipers??
The bolt spacing on the E38 brembos is different to the E32 540i ones.
clarko74
LondonTom
Post Thu Dec 18, 2014 10:38 am
What's the minimum size wheel you can run with this setup?
clarko74
Post Thu Dec 18, 2014 10:41 am
These will work with 16" Hartges but I think that is about the only 16"wheel that will work with this setup.
clarko74
LondonTom
Post Thu Dec 18, 2014 10:48 am
clarko74 wrote:These will work with 16" Hartges but I think that is about the only 16"wheel that will work with this setup.
Thanks Clarko.
Post Thu Dec 18, 2014 1:08 pm
I use a 25mm master cylinder
Some pics of mine here - http://www.e30zone.net/modules.php?name ... &start=200
Lurch320i
Post Thu Dec 18, 2014 6:19 pm
I fitted this setup with my 16" bbs lm reps
No spacer required but I did take a grinder to the caliper slightly to clear the inside of the rim
Post Thu Dec 18, 2014 7:11 pm
Whos make of BBS reps are they? Any pics?
satan16v
Post Sun Dec 21, 2014 9:48 am
Will this master cylinder be a straight swap? And improve the pedal feel, when running brembos up front and 540i rears?
http://www.ebay.co.uk/itm/301379572841
E53 X5 4.6is - SOLD
E36 M3 - SOLD
Kos
Post Sun Dec 21, 2014 11:01 am
DanThe wrote:Whos make of BBS reps are they? Any pics?
Demlotcrew had a set on his turd
www.pukardesigns.com
IG Pukar.Designs
Lurch320i
Post Sun Dec 21, 2014 3:29 pm
My reps are from a company called bmautosport
They look like this
Forgive the state of them, I'm currently in the middle of polishing the lips and painting ther centers
Post Sun Dec 21, 2014 11:23 pm
Any manufacturers markings on them?
Jozi
Post Sat Dec 27, 2014 4:18 pm
If you fit a bigger ms because of larger pistons and having to push more fluid does this mean the rears are more likely to lock up quicker because of more fluid being pushed down the lines?
keri-WMS
Post Sat Dec 27, 2014 4:37 pm
Jozi wrote:If you fit a bigger ms because of larger pistons and having to push more fluid does this mean the rears are more likely to lock up quicker because of more fluid being pushed down the lines?
Other way round, the larger m/c area creates lower line pressure for a given pedal force, the clamping force on the pads might be recovered at the front caliper with larger pistons (depending on the actual piston sizes) but the rears don't so you get a bias shift to the front.
bmw-mad
Post Sat Dec 27, 2014 6:06 pm
Do you have pictures?
As I Have the same setup
540 brakes and tt discs
the calliper wont clear my 16" alpina's
Post Sat Dec 27, 2014 8:51 pm
He said Hartges winkeye
I have the same problem, want to fit my Alpinas but the fronts need redesigning, new bracket/caliper and smaller disc. Rumour has it you need a 308mm disc to go under the Alpina wheel
Loads of pics in my thread, linked above
