E30 Lights Problem?
MPOWERCRAZY
Post Fri Dec 12, 2014 11:26 pm
Friend of mine took his car out after being parked up for 2 months or so. Said all lights were working until he parked up were all the lights (headlights,dims & back lights ) turned of, also the hazards have stopped working to but indicators still working? Anyone know what could be the problem?
Post Fri Dec 12, 2014 11:35 pm
Hazards will be the switch itself in need of a strip and clean, or fuse 24 blown. If fuse 24 is blown, it's usually because some "auto electrician" has taken power from the wire to the switch, knowing that it is permanent live.
The first part of your question makes no sense at all.
MPOWERCRAZY
Post Fri Dec 12, 2014 11:42 pm
Before the car was parked up for a while all the lights were working including the hazards, he told me he started it up & put the lights on everything was working fine, when he parked outside his own house before turning the lights of himself they just turned of with the switch still being on.
Back Again From The Darkside Of Doing E36'S :mad:
Back With 2 E30 Projects :cool:
Post Sat Dec 13, 2014 10:04 am
What's the state of the electrics now? What works and what, if anything, doesn't?
Accurate and complete answer is important.
MPOWERCRAZY
Post Sat Dec 13, 2014 10:38 am
I've said none of the lights are working, which includes headlights, dims, rear lights...
Post Sat Dec 13, 2014 1:25 pm
ALL the electrics, not just lights.
MPOWERCRAZY
Post Sat Dec 13, 2014 2:03 pm
Fixed :D
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Dec 13, 2014 2:24 pm
So are you going to tell us what the issue was, or just leave us guessing?
MPOWERCRAZY
Post Sat Dec 13, 2014 3:19 pm
Grrrmachine wrote:So are you going to tell us what the issue was, or just leave us guessing?
I thought I've made it clear, all electrics are fine, suddenly all of the lights went of including headlights, sidelights & rear lights. What didnt i mention clearly??
jmc330i
Post Sat Dec 13, 2014 3:32 pm
I think he means how did you fix it?
James
'91 325i Sport
'93 318i touring 16v
MPOWERCRAZY
Post Sat Dec 13, 2014 4:11 pm
Low beam relay caused the issue, as that was the relay i replaced & everything started working again apart from the hazards which I'm still investigating but the indicators work, so not to sure
