5x120 to 4x100 - adapters or redrilling?
RobWill116
Post Mon Nov 24, 2014 1:33 pm
Hi there,
Found a set of e38 style 5's 16x8 et23 which I'm looking to purchase, only downside is they're 5x120.
Tried searching on here but couldn't find anything. If I went for 4x100 adapters, the et would be too low and have a huge poke wouldn't it?
So this would leave the option to get them welded and re-drilled, whats everyones experiences of this? Can you recommend anywhere to have it done? And how much did it cost?
The other option would be 5 stud conversion?
Cheers,
Rob
ross_jsy
Post Mon Nov 24, 2014 3:13 pm
The only real option is a 5 stud conversion. Everything else is pikey and gash
Post Mon Nov 24, 2014 3:16 pm
Here.
http://www.r3vlimited.com/board/showthread.php?t=230901
You'll need 18mm adaptoes, then you'll have a slight poke, which will need the arch lips rolling.
Post Mon Nov 24, 2014 3:52 pm
All that headache to fit some basic E38 wheels. I'd rather spend the money to get wheels that fit.
bab-91
Post Mon Nov 24, 2014 3:56 pm
ross_jsy wrote:The only real option is a 5 stud conversion. Everything else is pikey and gash
+1
IG - bab91
Post Mon Nov 24, 2014 3:57 pm
Blitz wrote:All that headache to fit some basic E38 wheels. I'd rather spend the money to get wheels that fit.
Yes yes, we all know your ALL OEM..
Demlotcrew
Post Mon Nov 24, 2014 3:59 pm
I think the conversion spacers are a good solution, I certainly wouldn't have any reservations in using them.
Post Mon Nov 24, 2014 4:01 pm
I'll be getting a set for my 5x120 17" Hartge and AC Schnitzer Split rims.
Or should I go against the grain and ruin them by drilling and filling Blitz??
Post Mon Nov 24, 2014 4:15 pm
Please do. I'll look forward to seeing the pictures.
Post Mon Nov 24, 2014 4:16 pm
Adaptors it is then
RobWill116
Post Mon Nov 24, 2014 11:30 pm
Ideally in the long run I'm after a set of 4x100 Mahle 16s, but seeing as they're really hard to come by that'll take some time. And the e38 wheels are costing me peanuts so will do for the meanwhile.
Adapters sound the best way for me, looked at drilling and the result is really messy. And seeing as in the long run I'll be going back to 4x100, 5 stud kind of out the question.
At the moment I've got bbs rz 15s, but they're just a tad too small for me
Post Mon Nov 24, 2014 11:40 pm
RobWill116
Post Tue Nov 25, 2014 9:07 am
Cheers for the links, definitely going the adapter route. Do you know whether he had to role his arches? I am currently running standard e30 springs so shouldn't be a problem with that, but when I get my b12 kit will i need to roll the arches? Should only be a 30-40mm drop.
hennared323i
Post Tue Nov 25, 2014 9:36 am
Rav335uk wrote:http://www.r3vlimited.com/board/showpos ... stcount=98
http://www.r3vlimited.com/board/showpos ... tcount=178
the owner is running 42 Draft Designs adapters 20mm rear 18mm front.
Those adaptors look an excellent bit of kit.
N reg?
Post Tue Nov 25, 2014 9:54 am
Its a show plate. That's not a UK car.
GemE30
Post Tue Nov 25, 2014 1:55 pm
RobWill116
Post Tue Nov 25, 2014 2:08 pm
I prefer the look of the 42 draft designs adapters than the ebay ones!
Post Tue Nov 25, 2014 2:49 pm
The usa adaptors are a better alrounder.
appletree
Post Wed Nov 26, 2014 6:37 am
Only thing I don't like about the US ones is that the if the kidney is say 10mm thick and the adaptor is 18mm thick then that's only 8mm for the stud over the kidney to screw in main adaptor which isn't a lot as its not like the studs are shouldered from the back. I know it says they arn't for race applications but still you don't want it in the back of your mind the next tiome your pushing on do you!
Also Kerry uses the same grade alloy iirc on his brake caliler carriers but uses steel helicoils to protect the softer alloy, it will always be a compromise..
"Why do WMS use threaded inserts?"
They are about getting the best of both worlds. Aluminium brackets are easily strong enough to take the loads created during braking, but have a few issues:
- Aluminium is a bit soft to have threads in it if the bolt is taken in and out a lot.
- They are also at risk from people fitting extra washers and/or shorter bolts etc resulting in less engagement, or over-torquing, basic human error etc.
Steel/Stainless brackets on the other hand are fine for the threads, but also have issues:
- They are heavy.
- They are also very expensive to machine.
By fitting heavy duty stainless inserts into aluminium you get the lighter bracket, but with the stronger threads! In effect the aluminium "sees" a much larger bolt/thread so it has an easier life. Other things worth noting:
1 - The inserts are 431 or 303 Stainless Steel. 431 is a VERY high grade of steel, in fact its properties and tensile strength are similar to a Grade 12.9 bolt (think ARP rod bolts etc).
2 - The inserts are fixed into the bracket with a grade of Locktite retainer that can withstand high temperatures (the softening/"disassembly temperature" is 250 degrees C) and is fully resistant to motor oil, unleaded petrol, brake fluid and ethanol.
3 - In destruction-testing we tried to pull an M10 bolt/insert out of a bracket by over torquing it. It made it to 80FtLb (twice the 40FtLb suggested for use one the car) before the Grade 12.9 BOLT stretched.
4 - Lastly this is not an untested concept: Wilwood's own USA-market brackets are aluminium with threaded inserts as well.
Post Wed Nov 26, 2014 9:03 am
ross_jsy
Post Wed Nov 26, 2014 10:21 am
appletree wrote:Only thing I don't like about the US ones is that the if the kidney is say 10mm thick and the adaptor is 18mm thick then that's only 8mm for the stud over the kidney to screw in main adaptor which isn't a lot as its not like the studs are shouldered from the back. I know it says they arn't for race applications but still you don't want it in the back of your mind the next tiome your pushing on do you!
This. Why compromise on such a critical part. Do it right and do it once imo.
Demlotcrew
Post Wed Nov 26, 2014 10:25 am
You could race with only three bolts in and the wheel wont come off. Not an issue, for road use they will be fine.
ross_jsy
Post Wed Nov 26, 2014 10:32 am
I would just rather do it properly.
Plus, they look rather unbalanced. Obviously the effect will be limited due to it being close to the centre of rotation
RobWill116
Post Wed Nov 26, 2014 2:17 pm
ross_jsy wrote:I would just rather do it properly.
By properly I presumed you mean 5 stud conversion as per your earlier post?
I know what you mean, but in the long run I would have to convert back to 4 studs if I can find a set of Mahle 16s - which may take a while!
appletree wrote:- Aluminium is a bit soft to have threads in it if the bolt is taken in and out a lot.
I won't be planning on taking the bolts off a lot, the set i've got have new tyres so once they're on they should be on for a while.
Sounds like there's a business venture there for somebody to add steel inserts to the adapters winkeye
Motorhole
Post Wed Nov 26, 2014 3:05 pm
The 42 Draft Designs solution looks pretty neat, but very expensive for no other benefit than to fit 5-stud wheels! As has been said before, a better solution is just sourcing the right wheels in the fitment you need - or getting some made up.
When the 5-stud conversion is done properly, you end up with wider track, bigger wheel bearings and big 315mm brakes - downsides: although the reduction in castor is small when done correctly, there is quite an increase in unsprung weight. Doing it just for the wheels alone is fruitless really.
HairyScreech
Post Wed Nov 26, 2014 5:30 pm
Motorhole wrote:The 42 Draft Designs solution looks pretty neat, but very expensive for no other benefit than to fit 5-stud wheels! As has been said before, a better solution is just sourcing the right wheels in the fitment you need - or getting some made up.
Agreed, the brakes is the big reason I am pushing down that route.
Track is the secondary benefit as is commonality of parts in future for a daily driver. (i'm sleeving and using non M parts)
Wheels is just a fringe benefit really.
Demlotcrew
Post Wed Nov 26, 2014 5:59 pm
The other issue is the steering feel, the E36> hardware is designed for a totally different wheel base/track. Just look at the distance between the outer ball joint pivot point and the tie rod pivot point on the hub, much longer than the E30 :(
appletree
Post Wed Nov 26, 2014 6:35 pm
RobWill116 wrote:
appletree/Keri WMS wrote:- Aluminium is a bit soft / to have threads in it if the bolt is taken in and out a lot.
Keris quote is with regard to brakes and the caliper mounts, and the number of times you remove the calipers to change the discs/pads if it's a consern for him it would make sense to apply this to the adaptors as you have to remove your wheels to get to the brakes :D
Also as the adaptors have studs anyway it's not the alloy that will wear, my point was to the stud its selfs not in a helicoil in the adaptor where it's anchored. But I copied the hole helicoil section from Keris post as it was relevant.
Demlotcrew wrote:You could race with only three bolts in and the wheel wont come off. Not an issue, for road use they will be fine.
If you can race on 3 bolts why not do away with the stud on the kidney and use proper sized counter sunk bolt and just run your 5 stud wheels with 4 nuts on then winkeye winkeye :D :D
Post Wed Nov 26, 2014 7:00 pm
You could tiger seal the 5th bolt head on for MOT purposes innit
appletree
Post Wed Nov 26, 2014 9:03 pm
DanThe wrote:You could tiger seal the 5th bolt head on for MOT purposes innit
Job done!
or just tiger seal the wheel on and save your self a load of agro! :twisted:
HairyScreech
Post Thu Nov 27, 2014 1:24 pm
This and the effect is not to be underestimated.
The e36s steering angles don't match up, I took a look at it a while ago, the e36 bits wont give enough inside steering angle and Z4 bits will give too much. Tyre scrub will be significant.
I have not found a suitable knuckle yet but meant to take a look into E46 ones.
Adjusting the steering angles on the hubs might be possible with a strong enough jig but it doesn't change the castor thing.
Motorhole
Post Thu Nov 27, 2014 5:07 pm
HairyScreech wrote: I have not found a suitable knuckle yet but meant to take a look into E46 ones.
Can get a complete E46 strut assembly (strut, kingpin etc) off Ebay for £20. Tempted to get one just to offer it up and take some measurements, compared with my current E36 setup.
HairyScreech
Post Thu Nov 27, 2014 5:19 pm
If got a knuckle at home, just don't have the strut top positions etc.
Ill dig up the track widths etc tonight as something with a similar track width vs wheel base will be a start to search from, the e36 is just too long and lacks the castor of the e30.
HairyScreech
Post Thu Nov 27, 2014 11:48 pm
Did a little bit of checking when I got home, one of the issues with the e36 bits is the steering angles, which is largely affected by the width to wheel base ratio.
Constructing a few lines from the track width to the center point of the rear axle and checking the angle they produce gives me.
E30 - 30.61 deg included angle.
E36 M3 - 29.51 deg included angle.
E46 - 30.86 deg included angle.
Now provided that these cars are set up for neutral scrub radii then the e46 hubs might solve the steering angle issues.
That is given the castor etc works out as well.
davelarge
Post Fri Nov 28, 2014 3:12 am
Just run adapters if you plan on going back to a 4x100 wheel in the future anyway, most people that have bad things to say about them have never used them!
I had 5x130/4x100 adapters when I had porsche wheels and never had a problem, I also had a welded diff so extra strain would have been put on the wheels compared to normal road use and still they where fine. I think they have a bad rep because it's normally 17 year olds with VW's who use them and don't torque them up correctly and they end up having a wheel fall off. :mad:
