Exhausts
pony
- I have been misbehaving and am sorry !
Most exhausts don't sound as good in sound clips unless in personleeparkes wrote:Do a sound clip when its fitted
Except the E60 M5 with straight through exhaust on Powerflow social networking page
pony
I will probably keep the old centre section so should I want a straight through in the centre section in the future they can use the exhaust flanges to build this without butchering the other pipes or OEM fittings and also should I ever sell it a full Scorpion should hopefully sell well
ross_jsy
They don't have a x pipe, nor is there anything that looks like a x pipe in that picturepony wrote:This is PDF of the full exhaust system by Scorpion
Am I correct / incorrect in thinking the downpipe section has x-pipe section ?
http://www.scorpion-exhausts.com/sitead ... sbm014.pdf
ross_jsy
And back to my earlier question, how was he going to fit a x pipe to a single pipe exhaust, and even better how was he going to charge you £100 for the privilege? Did the workshop have a glass door because he saw you coming
pony
He wanted to do single pipe maybe to save costs and labour for himselfross_jsy wrote:And back to my earlier question, how was he going to fit a x pipe to a single pipe exhaust, and even better how was he going to charge you £100 for the privilege? Did the workshop have a glass door because he saw you coming
I did tell him I wanted x pipe as Kos was saying I should have it
The exhaust guy was basically telling me I don't need it and waste of time / money
And to do x pipe would need 2 exhausts pipes not one
I weren't keen on having it all merged to single pipe
pony
I thought the bit by the down pipe where they appear to cross might be x pipeross_jsy wrote:They don't have a x pipe, nor is there anything that looks like a x pipe in that picturepony wrote:This is PDF of the full exhaust system by Scorpion
Sorry I don't know a lot about exhausts as much as you!!
ross_jsy
Ah fair enough, he seems like a bit of a cowboy. So £100 extra would have got you a twin pipe exhaust with x pipe?
You want the cross pipe to be roughly in the middle of the exhaust, but the position has an effect as well.
I used to have a scorpion. I don't think it's going to be as ASBO loud as you are hoping for
pony
Yeah at least I know I am getting tried and tested product
And designed by proper engineers not cowboys
I felt like I was getting ripped off a bit
The more I think about it I'm glad I went for it
I will keep the old centre section mainly for the flanges so I have the option in the future to make the scorpion straight through without butchering a new scorpion exhaust
Also I think all the Y sections would they hurt the exhaust gas flow ?
This where we need a Zoner with good understanding of fluid dynamics would probably help
pony
Yeah extra £100 I think he said but he was saying I don't need itross_jsy wrote:Ah fair enough, he seems like a bit of a cowboy. So £100 extra would have got you a twin pipe exhaust with x pipe?
ross_jsy
As long as the cross section of the single bore is of a good enough size, it shouldn't hurt flow. It's easier to get good flow rates from a large single bore than smaller twin pipes because flow rate increases exponentially with pipe size.
minesapint
How can straight through with a back box be OEM, when clearly they were built with a middle box.pony wrote:I think best option for OEM look is straight through then new BMW back box and new BMW chrome tips
That way looks OEM and loud
OEM is as they came out of the factory, and with the part made by the OEM manufacturer. Do you want it to look OEM or be OEM?
Also BMW no longer supply the two pipe back box for 325i.
pony
Would LOOK OEM but wouldn't quite be OEM and would sound better!minesapint wrote:How can straight through with a back box be OEM, when clearly they were built with a middle box.pony wrote:I think best option for OEM look is straight through then new BMW back box and new BMW chrome tips
Rear silencers and chrome tips are available from BMW I checked yesterday
minesapint
I checked today & unsuccessfully tried to buy one in the summer.Also BMW no longer supply the two pipe back box for 325i.
pony
Try contacting BMW Park Lane they said they were availableminesapint wrote:I checked today & unsuccessfully tried to buy one in the summer.Also BMW no longer supply the two pipe back box for 325i.
pony
I find this feature a good read on exhausts design
Says basically you want low back pressure high exhaust velocity
This of helped by having straight through mufflers and small pipe diameters
Large pipe diameters produce low back pressure but also low exhaust velocity which can harm engine power
http://www.mikekemper.com/elantra/diyexhaust/
Edit
BMW OEM pipe diameter is 45mm = 1.77 inches
BMW OEM (325i) tail tips is 60mm
This article says optimum pipe diameter is 2.25 inches for 2.5 litre NA engines
Seems then OEM pipe diameter is too small ....
Edit
steve_k
- Contact:
soni, have a read through this thread
http://www.r3vlimited.com/board/showthread.php?t=234145
should give you some idea how an X pipe works,
also google X-pipe theory.
pony
What we need is this company to make exhausts for E30 325i group buy
They make exhausts for F1 amongst many other Motorsport disciplines
http://www.primarydesigns.co.uk/design
pony
I'm like an excited school boy waiting for Scorpion full sports exhaust system
I rang up Scorpion to ask how many more bhp I could achieve with this. They didn't have any figures. Then I was like I can't wait for it and they were like they can tell I am excited from the mobile phone.
Anyway this was the reply I got to find out more technical information about the design and the power
Sent from my iPhone.
On 11 Nov 2014, at 10:08, "Stuart Reid" <Stuart.Reid@scorpion-exhausts.com> wrote:
Hi the famous Pony from E30 Zone,
325 E30 inc Cabrio & Touring
85-88
221BM
Down pipes
44.4mm 1 3/4"
Full system
200BM
Centre silencer
191BM20
Rear silencer
76mm LEMANS
SBM014
£619.57
Models with 3 piece O.E. system only.
416BM
Silencer strap
Will fit with O.E. Sport body kit.
080FK
Fitting kit
For auto fit NFP system.
Please see above product details,
Our system is designed to produce optimum flow through the pipework, thus improving performance without the need for an engine re tune.
With the product being produced a long time ago we do not have dyno figures to send to you.
The product is manufactured from T304 stainless steel and comes with a lifetime warranty.
Best regards,
Stuart
<image002.jpg> <image004.jpg>
Stuart Reid
Scorpion Exhausts
01773 744123
stuart.reid@scorpion-exhausts.com
Sent: 08 November 2014 20:36
To: Sales
Subject: Scorpion - Ask the Experts
NAME:Pony from E30 Zone (innit)
COUNTRY:United Kingdom
EMAIL:
MESSAGE CATEGORY:General
COMMENT OR ENQUIRY:
BMW E30 325i Sport 1987 Full Scorpion Sports Exhaust System Can you tell me more about the design of this exhaust how it helps performance ? And how differs from BMW OEM ? How much bhp increase ?
______________________________________________________________________
This email has been scanned by the Symantec Email Security.cloud service.
For more information please visit http://www.symanteccloud.com
85-88
221BM
Down pipes
44.4mm 1 3/4"
Full system
200BM
Centre silencer
191BM20
Rear silencer
76mm LEMANS
SBM014
£619.57
416BM
Silencer strap
080FK
Fitting kit
Best regards,
Stuart
Stuart Reid
Scorpion Exhausts
01773 744123
To: Sales
EMAIL:
COMMENT OR ENQUIRY:
- gooner1
- Out humping Reindeer
[quote="pony"]I'm like an excited school boy waiting for Scorpion full sports exhaust system
Anyway this was the reply I got to find out more technical information about the design and the power :-)
85-88
221BM
Down pipes
44.4mm 1 3/4"
Full system
200BM
Centre silencer
191BM20
Rear silencer
76mm LEMANS
SBM014
£619.57
416BM
Silencer strap
080FK
Fitting kit
Best regards,
Stuart.
And PLEASE stop Feckin phoning us.
Stuart Reid
Scorpion Exhausts
01773 744123
To: Sales
EMAIL:
COMMENT OR ENQUIRY:
For more information please visit :) :)
85-88
221BM
Down pipes
44.4mm 1 3/4"
Full system
200BM
Centre silencer
191BM20
Rear silencer
76mm LEMANS
SBM014
£619.57
416BM
Silencer strap
080FK
Fitting kit
Best regards,
Stuart.
Stuart Reid
Scorpion Exhausts
01773 744123
To: Sales
EMAIL:
COMMENT OR ENQUIRY:
pony
Just Le Mans tips for E30s
Kos swears they make more but I rang them up and spoke to them and they confirmed they just do Le Mans tips
I did tell Kos to ring them and sort some other tips if he is so confident
Cloggy Saint
