Did a search but couldnt find info on this.
People seem to use RX7 calipers with corrado discs. I have a set of 4 pot brembo calipers from an E38 i parted. Has anyone used these for an upgrade or are there serious fouling issues?
ta
Brembo brake upgrade
ajazyasin
sorry! was using wrong search phrase. got it now.
ajazyasin
im looking for the diagram for adapter plates if anyone has them?
ta
ta
ajazyasin
Id really appreciate help on this peeps. I dont fancy going through mock up.
thanks
thanks
jmc330i
You could try searching some of the US forums. I don't think many on here have used those calipers as there are off the shelf kits available.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
ajazyasin
if i didnt already have the calipers, id probably get a kit.
ill keep searching but any help is appreciated
ajazyasin wrote:if i didnt already have the calipers, id probably get a kit.
E38 Brembos are practically worthless as the pitch is miles off. IIRC somebody did supply a kit with a bit of angle iron and Ca 30 mm of washers / spacers
ajazyasin
ah, ok. so they haven't been used successfully?
ajazyasin wrote:ah, ok. so they haven't been used successfully?
You could say that
