Brembo brake upgrade
ajazyasin
Post Sun Sep 21, 2014 9:39 pm
Did a search but couldnt find info on this.
People seem to use RX7 calipers with corrado discs. I have a set of 4 pot brembo calipers from an E38 i parted. Has anyone used these for an upgrade or are there serious fouling issues?
ta
ajazyasin
Post Mon Sep 22, 2014 12:17 am
sorry! was using wrong search phrase. got it now.
ajazyasin
Post Mon Sep 22, 2014 9:24 am
im looking for the diagram for adapter plates if anyone has them?
ta
ajazyasin
Post Tue Sep 23, 2014 9:22 am
Id really appreciate help on this peeps. I dont fancy going through mock up.
thanks
jmc330i
Post Tue Sep 23, 2014 9:33 am
You could try searching some of the US forums. I don't think many on here have used those calipers as there are off the shelf kits available.
James
'91 325i Sport
'93 318i touring 16v
ajazyasin
Post Tue Sep 23, 2014 2:09 pm
if i didnt already have the calipers, id probably get a kit.
ill keep searching but any help is appreciated :)
Post Tue Sep 23, 2014 3:24 pm
ajazyasin wrote:if i didnt already have the calipers, id probably get a kit.
E38 Brembos are practically worthless as the pitch is miles off. IIRC somebody did supply a kit with a bit of angle iron and Ca 30 mm of washers / spacers :eek:
ajazyasin
Post Tue Sep 23, 2014 5:01 pm
ah, ok. so they haven't been used successfully?
Post Wed Sep 24, 2014 9:54 am
ajazyasin wrote:ah, ok. so they haven't been used successfully?
You could say that :eek:
