Car has a sva test.
BROOMY
- busy saving Clifford
Sorry if wrong category
Car has an sva test coming up what has to work and what's what?
All help needed please
maxfield
Afaik it's just a bit more of an in depth MOT.
BROOMY
Which is what my friend.?
kam-325i
SVA Test.........Why ?
Its a bit more than an "in-depth MoT"
SVA is a "Single Vehicle Approval"......
kam-325i
The Single Vehicle Approval (SVA) scheme is a pre-registration inspection for vehicles that haven't been type approved to British or European standards. The purpose of the scheme is to ensure that these vehicles are designed and constructed to suitable safety standards before they are used on public roads.
maxfield
It's not something I've ever looked into what's involved.
I did some work for someone one day for getting the car through the test.
That involved a fitting an alarm, wiring in a rear fog and fitting something in the fuel cap so just an unleaded nozzle would fit. May of been other things as it was a few years ago.
kam-325i
The SVA test is quite anal, they will check the spacing's of the clips that fix the fuel and brake lines !!!
An E30 should not need an SVA test, as the model already has "Type approval"....
maxfield
Christ that's a sad job
To add to what I've just put, that was on an imported Subaru.
capnmchl
Best off asking on a kit car forum. The majority of them will have had to of gone through one. As Kam says, it's a lot more in depth than an MOT, and is actually meant to be more strict in some areas than the type approval proper manufacturers go through. There's a lot of stuff to do with measurements, like distance of the indicators from centre etc, all that bollocks.
HairyScreech
The first thing to point out here is that it wont be an SVA. It will be an IVA.
You need to do some googling for the current IVA manual, I have it here but can't remember the link.
As it is a full bodied car that has been used on the road before then you will only be looking at a BIVA so only those sections are relevant.
Overly modified monocoque?
kam-325i
The only other thing it could be is an Identity check of the car....
BROOMY
The car had an accident and they said I think it needs an SVA off memory.
It's all in writing somewhere , but gme a list of things they check on an IVA test.
It could be an identity check like already said.
HairyScreech
A VIC check?
jmc330i
Have you just bought the car? Who is they?BROOMY wrote:The car had an accident and they said I think it needs an SVA off memory.
It won't be an IVA test for an accident damaged car, it will probably be a VIC which is simply to check the vehicle ID against the dvla records. That said, the car needs to be road worthy with no defects.
If the car was written off by the insurance company (either a cat c or d) a VIC marker will be put on the car (registration certificate). The car can be repaired and used on the road again, but only once it passes the dvla VIC.
The car will need to be MOTd and insured if you want to drive it to the VIC test - my brother trailered his to the VIC test as the MOT ran out while he was repairing it.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
BROOMY
This is gonna confuse you all.
I owned the car 10 years ago well my mum and dad did.
The car got into an accident anyway they forgot which test it has to go so I'm kinda looking but you could be right with the vic check.
Nobby_N
Poor cat!
HairyScreech
They won't even look at a lot of cars now on the VIC unless it has an MOT.
BROOMY
Didn't think they could even get 1?
I think they check the alarm.
Grrrmachine
- E30 Zone Wiki / Team Member
pacerpete wrote:I think they check the alarm.
BROOMY
Dam I'm stuffed.pacerpete wrote:I think they check the alarm.
Ain't looked at it for a while.
andyp
- True Old Skooler
from memory I think you are right it has to have the check then an MOTBROOMY wrote:Didn't think they could even get 1?
BROOMY
Mines fine to drive like all brakes fine so would mine pass.
BROOMY
How would I find out which kinda test mine needs.?
BROOMY wrote:How would I find out which kinda test mine needs.?
If you do not know, we won't be much help !
PS, hows the alarm ?
BROOMY
The kid told me and gave me a piece of paper somehow I misplaced it.
Alarms all fine still don't work tho
BROOMY
Who would I ring to find out.?
HairyScreech
The dvla.
BROOMY
So I'm Gonna book the VIC check like has been told
Will they just check the vin numbers and those sorta things no need to start the car or anything ?
It has to be able to move under its own power, but apart from that, it can be far from complete and road legal.
BROOMY
Oh ok it can do that
