COMETIC
leecjones
Post Mon Jul 28, 2014 8:50 pm
Hi all,
Im trying to get hold of a cometic head gasket.. or something that is as good for my m20b25
details.. Performance MLS head gasket, thickness 1.78mm, bore 85mm. Suitable for BMW M20B25 & M20B27 2.5/2.7L 6-Cylinder
Needed asap.. ie this week
age
Formerly twist316
Post Mon Jul 28, 2014 9:31 pm
Vac will over night them from the usa if you cant find one this side of the pond
M40 rightness if you can get to 6000rpm noone can hear your tappets
leecjones
Post Mon Jul 28, 2014 10:00 pm
brill ta
craigieeb
Post Mon Jul 28, 2014 10:06 pm
HairyScreech
Post Tue Jul 29, 2014 12:10 am
Your spec sounds pretty standard, why do you need an MLS?
reggid
Post Tue Jul 29, 2014 1:48 am
dealer gasket or goetze will work, though can be difficult to find 1.75mm gasket most seem to stock 2.05mm (+0.3mm)
E30 325is with M20B31
age
Formerly twist316
Post Tue Jul 29, 2014 12:01 pm
My guess is he is putting a snail on it
age
Formerly twist316
Post Tue Jul 29, 2014 12:02 pm
HairyScreech
Post Tue Jul 29, 2014 5:11 pm
A stock gasket with studs should hold a fair bit of boost on a good well faced block with correct torque.
In a pinch a stock one would be fine provided you didn't boost the crap out of it.
