Issue Or Not?
MPOWERCRAZY
Hi All,
A family member of mine has just purchased a 325i sport for the summer, he's had it fully serviced including all new pads around, he was going to get the water pump & timing belt changed next however he took it to a garage & they said the engine is no good due to it cutting of once oil cap is removed? The idle is fine with the oil cap on obviously but once it's removed it totally cuts out
Also the seller said the car has been parked up for a year to if that makes a difference?
Can someone tell me whats going on here? Would be appreciated.
MPOWERCRAZY
Ok, shall i check all rubber hoses then for cracks etc?
Back Again From The Darkside Of Doing E36'S
Back With 2 E30 Projects
Your friend needs a new garage !
MPOWERCRAZY
He has been put of the car totally, he thinks its a knackered car now based on what someone has told him, do you know if its true or not if it should cut out once the oil cap is removed as i cant find many threads on thispacerpete wrote:Your friend needs a new garage !
Rich320I
sounds like the garage may be after buying a cheap 'knackered' BMWMPOWERCRAZY wrote:He has been put of the car totally, he thinks its a knackered car now based on what someone has told him, do you know if its true or not if it should cut out once the oil cap is removed as i cant find many threads on thispacerpete wrote:Your friend needs a new garage !
MPOWERCRAZY
To be honest im not sure if it's true or not that's why i created this thread to find out the problem, the engine doesn't seen knackered as it idles well cold & warm also picks up speed well, so not to sure on who to believe or notRich320I wrote:sounds like the garage may be after buying a cheap 'knackered' BMWMPOWERCRAZY wrote:He has been put of the car totally, he thinks its a knackered car now based on what someone has told him, do you know if its true or not if it should cut out once the oil cap is removed as i cant find many threads on thispacerpete wrote:Your friend needs a new garage !
Rich320I
id believe that, the garage has more to gainpacerpete wrote:Your friend needs a new garage !
MPOWERCRAZY
So is the garage wrong then or rightRich320I wrote:id believe that, the garage has more to gainpacerpete wrote:Your friend needs a new garage !
Rich320I
id be thinking it was an air leak, but then i havnt seen the car and the garage could be a bunch of e30 expertsMPOWERCRAZY wrote:So is the garage wrong then or rightRich320I wrote:id believe that, the garage has more to gainpacerpete wrote:Your friend needs a new garage !
MPOWERCRAZY
Few people are mentioning air leaks too so will have to check all ruber pipes today. Not to sure in garage as I've never used him before
Rich320I
http://www.e30zone.net/e30zonewiki/inde ... #Air_Leaks
read this and go through the places leaks can occur, when you remove the filler cap your letting alot more air in so if there is already an air leak, it could explain why the engine cuts out.
MPOWERCRAZY
Thanks for the link, will carry out the checks shortly & hopefully sort itRich320I wrote:http://www.e30zone.net/e30zonewiki/inde ... #Air_Leaks
It is NORMAL for a M20 to run poorly / cut out if the oil cap is removed. You are creating a huge air leak in what should be a sealed crankcase. Removing the engine oil dipstick will have a similar, but not quite as severe effect .
The garage are at best not familiar with these cars which is a sure warning to remove his car , really quickly !
- **BANNED**
'Birmingham sport' init,bruv....
Youth is wasted on the young.
MPOWERCRAZY
Mmm ok, but should i still check for the air leaks just to be certain? & the car is not at the garage he took it back to his house after what he was toldpacerpete wrote:It is NORMAL for a M20 to run poorly / cut out if the oil cap is removed. You are creating a huge air leak in what should be a sealed crankcase. Removing the engine oil dipstick will have a similar, but not quite as severe effect .
MPOWERCRAZY
daimlerman wrote:'Birmingham sport' init,bruv....
MPOWERCRAZY
Also i don't see how thats relative to my topic, I'm asking for advice which is why i put this up on this section.daimlerman wrote:'Birmingham sport' init,bruv....
sunnysr
Sounds knackerd I will get you a hundred quid take it off your hands .
My standard m20 does that cuts out when the oil cap is off and runs 14.8 second 1/4 mile times ...so I doubt there is much to worry about really.
MPOWERCRAZY
Lol sarcastic much, but i am checking for air leaks now to be sure.sunnysr wrote:Sounds knackerd I will get you a hundred quid take it off your hands .
joeadams1979
what colour sport is it?
Removing the oil filler cap on an E30 M20 engine should make the engine run extremely roughly. If the car has been stored without a battery connected, then the ECU will have lost its base idle settings, and it wouldn't be at all surprised if it stalled.
Gert_8
I remember, in my younger day, topping up with oil and then forgetting to put the cap back. It ran like a rough dog.
It had made a pretty good mess when I lifted the bonnet to check. Thankfully the cap was still sitting on the radiator
MPOWERCRAZY
The car now doesn't cut out once the oil cap is removed, it's runs rough obviously once removed but once put back in runs like a dreams, there were two perished hoses which were replaced! So after all it's not a knackered engine! Onto the next step....thanks for all the help
