Does anyone know much about the e30 amps
jonny323i
Post Tue Jul 15, 2014 6:55 pm
Iv got this original e30 amp and loom does anyone know where everything should be mounted and what the extra plugs are.
Touring for life
Post Tue Jul 15, 2014 7:09 pm
Brown will be earth, and the wire with the fuse holder attached will probably be live +12V.
Then, there will be probably two inputs, for left and right, and corresponding outputs to the speakers; those will probably be the twisted yellow and blue pair.
jonny323i
Post Tue Jul 15, 2014 7:12 pm
Iv figured out the basics and can identify all the outputs from the stereo but for each of the speaker connections there is another single blue connector are they for tweeters.
Touring for life
jonny323i
Post Tue Jul 15, 2014 8:35 pm
There is one on each speaker out put mate
Touring for life
Post Tue Jul 15, 2014 9:52 pm
Could well be. Does the amp have a make/part number on it?
jonny323i
Post Tue Jul 15, 2014 10:27 pm
It's the blaupunkt Bavaria quadro booster 7607395140 or 65121375983
Touring for life
jonny323i
Post Tue Jul 15, 2014 10:31 pm
Never thought of looking it up on real oem
Touring for life
beemerbird
Jonny - I think you need to find out where it would have been originally fitted. That cabling is so tightly loomed that the location will pinpoint the function of each wire and socket.
A single wire is no good to a speaker of any kind, btw :)
Edit. Just spotted you've identified it as a quadro booster system? This probably means that it allows you to split front right, front left, rear right and rear left for individual control. The single wires will be to send position specific +ve signals to each of these locations, the -ve being non crucial.
I'm not a BMW audio expert, but I know a bit about sound :wink:
Post Tue Jul 15, 2014 11:05 pm
beemerbird wrote: A single wire is no good to a speaker of any kind, btw :)
Depends on whether it relies on the speakers being earthed via the car's chassis or not...
jonny323i
Post Wed Jul 16, 2014 6:17 am
Looks like the loom does earth to the body
Touring for life
Post Wed Jul 16, 2014 7:44 am
Blue wire is normally electric aerial / trigger wire and considering that main plug looks like it goes into the main distribution point behind the glovebox, it could be the case here.
Post Wed Jul 16, 2014 7:48 am
jonny323i wrote:Looks like the loom does earth to the body
In which case I'd say this is the main ICE loom which when fitted to the car, connects the amp and head unit together, hence theres an earth tab, the main connector to the distribution points behind the glovebox and a single blue wire which I think is aerial power.
Post Wed Jul 16, 2014 11:11 am
Surely, the aerial trigger would be driven from the head unit?
Perhaps the extra wire(s) go to a graphic equaliser, or the speaker balance control rheostat...
beemerbird
Post Wed Jul 16, 2014 4:20 pm
If as B7 states, the amplifier goes in the glove box; assuming it's not been tampered with, the places at which the cables with connectors on peel off the loom will give you a pretty good idea of where it will route in the car, and therefore the function of the various wires :)
jonny323i
Post Wed Jul 16, 2014 5:35 pm
According to the diagram above it would fit behind the car jack
Touring for life
Post Wed Jul 16, 2014 5:53 pm
Interestingly, it was specified for most E30s, apart from the 316(i) and 320i:
http://www.realoem.com/bmw/partxref.do? ... series=E30
jonny323i
Post Wed Jul 16, 2014 5:58 pm
I never had them and iv only ever had 323i and 325i
Touring for life
Post Wed Jul 16, 2014 6:00 pm
Yes, I was just wondering why they wouldn't list it for the 316(i) and 320i versions also, seeing as these were very popular models in the UK and across Europe.
Post Wed Jul 16, 2014 6:54 pm
the blue and white single pin plugs are for the front tweeters and the corresponding for the door looms are in the foot well next to the front speakers.
Someone has bodged in a fuse holder with orange wire (possibly pioneer) and some scotch lock action.
The off set white four pin plug is the main power and earth plug for the head unit and plugs into the junction box behind the glove box.
The amp goes on the N/S of the boot in front of where an electric aerial normally goes.
jonny323i
Post Wed Jul 16, 2014 7:03 pm
Would there be any advantage to wiring this in with a modern head unit with a 50x4 output
Touring for life
Post Wed Jul 16, 2014 10:06 pm
Doubtful. It's best to use it with period head units.
Post Wed Jul 16, 2014 11:17 pm
jonny323i wrote:Would there be any advantage to wiring this in with a modern head unit with a 50x4 output
Nope.
The Quadro amp is 20w x4.
Post Wed Jul 16, 2014 11:28 pm
The factory hifi pack amp is fitted in the n/s/r quarter above the n/s/r arch in the boot.
beemerbird
Post Wed Jul 16, 2014 11:49 pm
pacerpete wrote:The factory hifi pack amp is fitted in the n/s/r quarter above the n/s/r arch in the boot.
Thank feck for that. Now you can work out blah blah blah :roll:
