After tuning around 180 degrees in a side road my steering has become very heavy.
My initial thoughts were that the belts flung off when on full lock but thats still connected.
There are no leaks and the reservoir is full although seems a little thin, i'm going to change the fluid now hopefully that helps.
Are the pumps a know failure point? The cars a 1993 M40 Tourer.
Power steering Heavy
trojen
Grrrmachine
- E30 Zone Wiki / Team Member
Belt might be on, but it may be loose or so old that it's gone glassy (which causes slipping).
I've not heard of a pump failing on here, but it's a moving part so that could always happen.
- **BANNED**
I had a power steering pump fail three or four years back,thing was whining worse than 'er indoors,about an inch of end float at the pulley!
Youth is wasted on the young.
trojen
So i've changed the belt and fluids and still no joy. Pumps next.
The belt is spinning the pulley but its almost as if drive shaft to the pump has sheered.
daimlerman - i couldn't here the typical whining nose although it is a M40 work horse so i probably couldn't here it over the tappets........
sindako
first Check out the Fluid . if it's goin from red to Black that mean your pump is out and it's taking the driven steel from it to the rack which makes it heavy .
if that is not your prob .
then
if you know how to do it .
i recommend Getting a rebuild kit .
Also when buying get the ZF branded ones .
They're better then meyle .
Needs alot of work but it'll run good .
then
