m52 auto to manual conversion
bigdoe
apart from the box,flywheel and clutch is there anything else that needs adding/changing to complete the conversion?.
AndyZippy
Hey man, my M52 was an auto and i converted to manual. That's it, although it meant my flywheel has no (manual-specific) spreader plate to go behind the bolts on the flywheel - Danthe managed to sort me one, You may have one but worth mentioning
Is your car auto too, or just the m52 engine?
bigdoe
it's just the engine i'm using has come out of an auto.
AndyZippy
BMW_E30vert
I think you also need to fit a spigot bearing if the engine was previously an auto
AndyZippy
Ah yes my bad, you do. What box have you got, bigdoe?
bigdoe
it's a 5 speed box out of a 328i,where does the spigot bearing go?.
