alexm3uk
Post Fri May 30, 2014 10:12 pm
Started stripping the m3 getting ready for paint :)
I see a a few more weeks of labelling and boxing parts up :( and of course ordering new parts lol
Rich2388
Post Sun Jun 01, 2014 1:09 am
Finally got mine back on the road after the crash damage back in feb.
New wing
New bumper with new smoked crystal front repeaters
Then the finished product
Before
After with a nice wash
And with the angel eyes and new front smoked crystal repeaters. Not to everyones taste i know.
Proper happy!
Jesus325iTouring
Frog freak !
Frog freak !
Post Sun Jun 01, 2014 5:57 pm
Don't get to post on here very often, but today I washed my Touring for the first time in 3 years :o: And without heeding any "laid up" advise, I chucked a battery in it and fired it :D Fired first turn, ran the second and continue into a lovely silky 6 cylinder idle :cool:
jimbom30cab
Tech 1 freak
Post Sun Jun 01, 2014 6:17 pm
Result Jesus
kieran325
Post Sun Jun 01, 2014 7:39 pm
Washed, polished and waxed the sport ready for its mot tomorrow, its only done 170 miles since its last mot :(
Jesus325iTouring
Frog freak !
Frog freak !
Post Sun Jun 01, 2014 7:57 pm
jimbom30cab wrote:Result Jesus
Indeed Jim, I didn't expect such willingness to start TBH, good old E30's :P
Mitchen
Post Sun Jun 01, 2014 11:00 pm
Changed brake pads, discs, drums and shoes! Never had so much grief trying to change shoes as I did today! Spent hours on those buggers. I've got cylinders as well but gave up as the brake lining fitting behind hub is rusted to fook and wouldn't budge! Last thing I need is a broken brake pipe. I'll pay someone else to solve that problem! Productive day though, the brakes have never felt so good 8)
1990 320i Coupe SE
viewtopic.php?t=253048
spook
League two here we come !!!
Post Fri Jun 13, 2014 11:15 pm
Cleaned it :D
jimbom30cab
Tech 1 freak
Post Fri Jun 13, 2014 11:18 pm
had a race against a Tech1 and lost.....badly
iDreamBeemer
Post Sun Jun 15, 2014 4:40 pm
Had the arches rolled and finally fitted my new wheels
jimbom30cab
Tech 1 freak
Post Sun Jun 15, 2014 6:29 pm
went to a local car show with some other e30s
jimbom30cab
Tech 1 freak
jimbom30cab
Tech 1 freak
Post Sun Jun 15, 2014 6:30 pm
Falamon
Post Fri Jun 20, 2014 8:30 am
Mitchen wrote:Changed brake pads, discs, drums and shoes! Never had so much grief trying to change shoes as I did today! Spent hours on those buggers. I've got cylinders as well but gave up as the brake lining fitting behind hub is rusted to fook and wouldn't budge! Last thing I need is a broken brake pipe. I'll pay someone else to solve that problem! Productive day though, the brakes have never felt so good 8)
Did mine last weekend - I've also never done drums and they were a pain in the ar5e!
Pagid stuff seems to work well, I used the same parts as you and she's never felt so good under breaking!
Post Fri Jun 20, 2014 4:32 pm
Finally got around to changing the wiper motor and popped two more coats of "renovator" on the roof.
The radiator has had some rad weld in and two weeks down the road all is well.
beemerbird
Post Tue Jun 24, 2014 3:56 pm
I drove my daughter to nursery in mine, returned to the car, and the fecker wouldn't start. Radio came on, windows etc, etc worked. It felt like it wasn't properly engaged in P (it's an auto) and some kind of inhibit was in operation.
Following a visit from a very helpful RAC man (who was more than a little entertained by my willingness to help out) I finally drove my now screwdriver operated E30 to the BMW parts department to order a new ignition barrel and key :evil:
darkchild
Post Tue Jun 24, 2014 8:43 pm
Serviced and new rear exhaust section fitted. 'Tis running sweetly now. 8)
Post Tue Jun 24, 2014 9:04 pm
beemerbird wrote:I drove my daughter to nursery in mine, returned to the car, and the fecker wouldn't start. Radio came on, windows etc, etc worked. It felt like it wasn't properly engaged in P (it's an auto) and some kind of inhibit was in operation.
Not usually the barrel that's at fault. Usual culprit is the actual switch clipped onto the back - the hole in the part that engages with the barrel wears out of shape.
If the key won't start it, there's always pins 11 and 14 of the diagnostic socket!
beemerbird
Post Tue Jun 24, 2014 10:03 pm
The ignition switch element is in fine fettle, with only slight rounding on the lower part of the appeture. I've inspected it carefully.
Had you been with the car, you'd have realised it was barrel failure - the key (and the spare that the RAC man drove me home to get) would not turn to the ignition position. At all. Obvious mechanical blockage.
Thanks for the reminder about pins 11 and 14 :) I look low-rent enough driving an E30 to pre-school without popping the bonnet and short circuiting the diagnostic plug in front of the Bentley brigade :wink:
jimbom30cab
Tech 1 freak
Post Wed Jun 25, 2014 11:29 am
So if you ram a screw driver into the ignition barrel, can you then turn it ok?
beemerbird
Post Wed Jun 25, 2014 12:37 pm
No! The ignition barrel will not move to the ignition position at all. I'm just using that to apply and remove the steering lock using the key. You'll have to guess the rest, as it sounds like a beginners guide to how to steal an E30 8)
gooner1
Out humping Reindeer
Post Fri Jun 27, 2014 9:43 pm
Another MOT for the battlewagon. :D
Rich2388
Post Fri Jun 27, 2014 10:16 pm
Black kidney. I like lol a‘a
gooner1
Post Sat Jun 28, 2014 8:57 pm
Taxed it, and changed the front wheels so the tyres rotate in the correct direction.
Took them off to change the steering rack and mixed up which side of car they
should have been on. :o:
MOT tester didn't spot them either. :D
Rousey66
Post Sat Jun 28, 2014 11:39 pm
I drove mine all the way from Derbyshire to Torquay last weekend and used about half a tank on the way down! Winner fuel economy from the mighty little M40 winkeye
I've been on my hols all week down in Devon and done another 100 ish miles during the week and then drove back earlier today. Not a peep or problem out of her all week! Very impressed considering the number of broken down new motors I saw on the hard shoulder driving down and back 8)
I spotted a brilliant red touring whilst I was down there (the guy gave me a big thumbs up as I drove past) and a 320i cabbie which a young girl was driving (I say young, she looked a similar age to me.) anyway I gave her a thumbs up and a wave and she completely blanked me! How rude! If you're on here and some nutter in a red 316i waved at you whilst driving through Paignton it was me.
RizlaChris
Post Tue Jul 01, 2014 9:26 am
Today i brought my E30, lovely red 318i Touring, not moved from its heated garage in 8 years, has 65k on the clock and a stack of paperwork to go with it, it is mint, no rust anywhere, couple of odd scratches from where its been sat in the garage but thats all. As soon as my Fighter project is finished the work will start.
darkchild
Post Wed Jul 02, 2014 4:06 pm
Filled it with petrol (which must've at least doubled it's value!) and had a quick blast by the Norfolk coastline yesterday. :)
Washed it today and treated a couple of minor bits of surface rust on the sills.
Tax due at the end of the month. :(
kieran325
Post Wed Jul 02, 2014 5:26 pm
Had the M3 mot'd !!
The last time I filled it up was Feb, so a blast this afternoon managed to clear the tank for the next lot.
prospro
Post Wed Jul 02, 2014 7:13 pm
Cut some more big holes in the never ending welding job that is the project car. :mad:
samuraibaz
Post Wed Jul 02, 2014 8:40 pm
new engine TEST DRIVE uprated suspension TEST DRIVE uprated xmember TEST DRIVE!!!!!!!
gooner1
Post Thu Jul 03, 2014 9:06 pm
Air, oil, and petrol filter change.
Fresh oil in. Service lights reset.
Interior vacuumed and cleaned.
All vinyl and rubber cleaned and treated.
All glass cleaned.
Wheels cleaned and polished.
All ready for a long weekend in Weymouth. :D
Post Sat Jul 05, 2014 9:57 pm
Washed it. Its been off the road since 2011. Poor car.
