non vanos M50 2.8 budget engine build
Fri May 23, 2014 12:10 am
I'm thinking out loud here, Engine is a non vanos b25 . Am i right in thinking an M52 single vanos 2.8 crank would bolt straight into the bottom end and hey presto make a 2.8 M50?!
Both engines use the same length conrod at 135mm so i think it would work?
reggid
Fri May 23, 2014 3:48 am
E30 325is with M20B31
Fri May 23, 2014 3:16 pm
Great i just need to find a crank and i can build a pikey 2.8 non vanos engine on the cheap for my e34 turd
It will provide some much needed low end grunt
BMW_E30vert
Fri May 23, 2014 4:37 pm
Fri May 23, 2014 7:11 pm
You will need to change the pistons too, so therefore new rings and a hone to the bore, head gasket and while its off a refurb.
Would be mad not to change to the M52 siemens management while your on.
BUT, it would make much more sense to spend a couple hundred on a 2.8 engine with loom/ECU etc :)
Fri May 23, 2014 10:10 pm
why change pistons Dan, i'd happily fit an M52 but can you upgrade the management on an e34 then?
I don't want to get the head off it and into piston rings and all that sh!t just a quick crank swap with some new shells and off i go type of affair
Fri May 23, 2014 10:56 pm
Its not that simple, the 2.8 crank has an extra 9mm of stroke which will smash the fook out of the head on a 2.5 donk
As I said previously the quick/cheap way would be to fit a 2.8 complete with some wiring changes
reggid
Sat May 24, 2014 12:55 am
yeah you'd need the b28 piston and crank thought thats what you meant. stack height needs to be maintained.
we are talking cI blocks right? not hard new rings and hone if bores measureup well
perhaps you could use the eta rod the 4.5mm longer throw would be offset by the 5mm shorter rod lol
Sat May 24, 2014 9:23 am
yeah so what are the wiring changes? does the later M52 loom just plug into a non vanos e34 as one is from an e36 to start with
Sat May 24, 2014 9:56 am
Also the ali block would mean the front end will sit very high, but i guess you could fit some lowering springs which u can get as the iX has its own front springs which are different to the rest of the e34 range
leeparkes
Sat May 24, 2014 10:00 am
Iirc there is only 22KG difference between iron and alloy blocks so i dont think it would make that much of a difference.
Sat May 24, 2014 2:32 pm
It wont just plug in you will have to fit all the vanos gear etc, no point faffing, just get a complete engine
Sat May 24, 2014 6:58 pm
i get it but your saying fit the M52 engine complete with the siemens managment
Will the M52 engine loom plug into the e34 is my question, maybe an M52 from an early e39 would do it?
Sat May 24, 2014 8:16 pm
E39 looms are useless
It will plug in yes, the wires may need to be changed a little bit, im not 100% but its not difficult
Sun May 25, 2014 9:42 am
I'll investigate via google, the guys on the 5 forum fit the M52 but keep the M50 management which i guess is easy enough if its a vanos car, but mine isn't
Sun May 25, 2014 11:02 am
The M50 management is prehistoric in comparison, and is not even a tenth as adaptive as the Siemens
