e34 525iX very sad day
Post Sun Apr 27, 2014 11:40 pm
Sweeeeeet!
maxfield
Post Sun Apr 27, 2014 11:41 pm
bss325i wrote:You are correct Jamie, only failable on security, excessively chafed or damaged.
It's brake pipes I'm thinking of.
You started testing now?
Yes, only for a couple of months now. Such an interesting job :?
Post Mon Apr 28, 2014 12:02 am
I was keen and enthusiastic like you once!
Mine lapsed back in November and we don't test on site at ML so I haven't done a refresher.
maxfield
Post Mon Apr 28, 2014 12:08 am
I mainly did it for the pay rise.
But we have got a dedicated tester so I maybe do a maximum of 10 tests a week. So it isn't too bad.
Post Mon Apr 28, 2014 1:01 pm
Even Jordanian Royalty rolled in these:
http://tinyurl.com/odof4oq
winkeye
Topblag
Post Mon Apr 28, 2014 1:13 pm
Speedtouch wrote:Even Jordanian Royalty rolled in these:
winkeye
I've just bought a 525ix and would've plumped for one of honest executive "shooting brakes" if I hadn't.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Post Mon Apr 28, 2014 10:26 pm
I dropped the fuel tank down off the straps to check the rest of these breather pipes. Best bit of the whole car!
So i think we can be confident the fuel system is tight and ok for now !
mcbonio
Post Tue Apr 29, 2014 12:19 pm
Good lorn Simon, you're a sadist. :)
Post Wed Apr 30, 2014 9:43 pm
wishbone fun, its very similar to an e30/36 arm? IX arm on the left.
Realoem is telling porkies. States that iX use the same lolipop bush as the e46. Well to my eyes its the same size bush as the e30/36 bushes
I've got these M3 eccentric ones spare so this could spice up the steering levels to a point the 2wd crew with their shagged out steering boxes could only dream of. While i revel in the rack as fitted to these and the 9.6 0-60 time.
I recenlty bought theseZ 4M bushes but they are too big for the lolipop on the iX. Logic was the iX uses according realoem the e46 bush. Which the Z4M ones fit. Shame but these bushes will fit my e46 instead now but does anyone have some spare e46 lolipops with scrap bushes?
these are goosed saggy things fitted to the car.
I need another picture but basically the lolipops look the same to your eyes but they are a touch different. So i need to get some new bushes pressed in.
I could always fit the e36 M3 evo bushes which are concentric? for a bit less hassle as i wouldn't need to get the tracking redone
maxfield
Post Wed Apr 30, 2014 10:04 pm
You're saying you want to use M3 eccentric bushes to improve the handling?
Whatever bushes you use it's always good practice to get the tracking checked/adjusted after any suspension work.
Post Wed Apr 30, 2014 10:10 pm
It is, but not on this turd only whats whats needed and whats lying around of use!
I'm saying those stock bushes are shot, they're the same size as e30/36 so i can fit a solid bush from M3s , either the eccentric ones or concentric. Both will help it out alot compared to whats there, question is which ones, hmmmmm eccentric will add castor which will add some feel i guess
Post Wed Apr 30, 2014 10:12 pm
I have a pair of E46 housings I can swap you for a scampi and drink on Monday :D
BenHar
Post Wed Apr 30, 2014 11:03 pm
If you use the eccentric bushes make sure it doesn't put any strain on the front half shafts.
And from what I've heard of Pete's appetite you'd be better off going to the dealer than buying him scampi.
Ben
Post Thu May 01, 2014 1:12 am
thats a far point, maybe go concentric then, Pete your a nice man! Maybe i'll get those seatbelt stalks off you too
Post Thu May 08, 2014 11:14 pm
Still not sure on which wishbone bushes to use, but there has been progress elsewhere on this resurrection
I thought the rear exhaust box was iffy............... but it fell apart literally. The rear silencer was hollow, no baffles left at all!
These heatsheilds are always mullered and hanging off, so a nice bodgetastic effort with some crude steel spacers to hold it in place!
I got this genuine system on the bay, i had to collect but a much better bet than if i'd bought a new cheapie from tyre place or ebay.
it was letting in water here through this rubber grommet, high temp silcone should keep it dry and help get rid of the damp old car smell, noice
major weldings
turned into a quite a serious hole/effort!!
more work, this drivers side has had some serious mig action
The dub man :) :)
Looks pretty good a nice repair i think for this turd
I finally had the V5 come in the post so i could get a number plate for the front, but i've gone the whole hog and got this rear one also. My local dealer see it fit that this sh1tbox needs one of their stickers in the rear window :o
No matter how crap, a decent BMW badge is a must imo
theres some knackered ball joints on the front that need sorting out as another kind of wallet bash, so some serious digging into the world of car parts should mean i've not got to visit the main dealer who want £220 per wishbone and £103 for each inner ball joint! Both inners have split gaiters/boots and play plus the passenger outer ball joint in the arm is kaput.
gareth
Post Fri May 09, 2014 12:49 am
All this effort and it's still got moss on it? Now that is rat look! :D
Post Fri May 09, 2014 4:13 pm
fook washing it! Gareth i'd like the make the diff lock work or make it an LSD with the handle thingy, is it a case of a hydro handbrake fitted to the diff line somehow?
Post Fri May 09, 2014 4:40 pm
While your redoubtable dred-locked dub scummer is commendably wearing ear muffs and latex gloves, when operating an angle-grinder, he should really be wearing proper eye goggles and thick gloves. Oh, and tell him to get his hair cut! :wink: :nono:
gareth
Post Sun May 11, 2014 12:37 pm
Simon13 wrote:fook washing it! Gareth i'd like the make the diff lock work or make it an LSD with the handle thingy, is it a case of a hydro handbrake fitted to the diff line somehow?
I reckon that would do yes :) Well in a bodgetastic manner anyway! :)
What pressure does the PAS pump deliver? You really need to replicate that
TPS
Post Sun May 11, 2014 1:07 pm
Good work Simon, it's getting there
Jesus325iTouring
Frog freak !
Frog freak !
Post Sun May 11, 2014 1:09 pm
Speedtouch wrote: Oh, and tell him to get his hair cut! :wink: :nono:
There is no absolutely need for that kind of language Maurice, I shall be reporting you to a Mod for immediate detention :wink:
Simon, don't wash the car, my Transit has litchen growing on it, quality growth :D :D
TPS
Post Sun May 11, 2014 1:13 pm
I'll ban him now if you like :D
Jesus325iTouring
Frog freak !
Frog freak !
Post Sun May 11, 2014 1:16 pm
Good man :D
Post Sun May 11, 2014 1:26 pm
My Minor Traveller also has a decent moss plantation in its window channels. :)
suedenim
Post Tue May 13, 2014 9:14 pm
How rare are these? Only there appears to be one that'sbeen pprepped for sale at a dealers near me. Can make enquires if anyone is interested.
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
Post Tue May 13, 2014 10:14 pm
Pretty rare: "only 9,366 BMW e34 525iX were made, this model is very rare today."
http://en.wikipedia.org/wiki/BMW_5_Series_(E34)
Out of the total production of 1,333,412 built, that represents a mere 0.702% of the production!
Topblag
Post Tue May 13, 2014 10:24 pm
Aye, they are a lovely steed to cruise about in, can't wait for Ze snow.
Post Sun May 25, 2014 10:05 am
More work for all you iX perverts out there to chew over!
New inner ball joints lemforder and they came from France! was the cheapest price by far, also i plumped for the e36 m3 evo bushes for the arms
All back together but there is alot of play in the bearing hub area that i don't think the MOT man will like! :x
new windscreen in, the insurance is only £300 oh to be old and a slow motor eh?
picked this up off ebay for £25 it was collection only and in surrey :)
Rejoice, these are new never fitted flaps for my OCD interest in them
The dog guard pole was bent? How it happened i don't know, so its straight now all ready to roll
fully mudflapped up goes well with the 4wd theme me thinks and being a wagon/workhorse sh!tter. Proper brickies motor the B3 is too posh really
She drives well, number plate for the front and trims on so it almost looks normal
I've changed the oil and filter, not one noisey tappet its bloody quiet this M50, also a coolant flush it was on slightly rusty water as per :roll:
I adjusted the handbrake up on friday night and you guessed it, one of the cables is fucked, i've got one coming from euros for £11
The passenger wishbone is in the post from Germany so along with that and the front bearing its ready! Only 3 jobs to do and it should have a ticket the old heap
I reckon people will stop me in the street and try to buy it.
milescook
Post Sun May 25, 2014 10:18 am
Loving your work :D
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
Post Sun May 25, 2014 12:28 pm
Looking good, but why is it sitting so high at the front, and have you polished that o/s/f wing?
Post Sun May 25, 2014 11:27 pm
the wing is a replacement and its been laquered also hence the shine! all iX's sit high but i guess my SLS delete and mismatch rear springs mean its a bit too low on the back end
Post Mon May 26, 2014 12:02 pm
This guy reckons otherwise, and his looks quite low:
http://www.chew-the-fat.org.uk/forum/vi ... 48&t=23016
Post Mon May 26, 2014 4:16 pm
that car in the link had a snapped front spring! :mad: Plus there was a rare M-tech suspension option that lowered it the usual 20mm that could be fitted to it also
Mine doesn't sit alot different to it to be fair
Post Mon May 26, 2014 7:38 pm
Fair enough, I'll let you off lightly this time. :wink:
