e34 525iX very sad day
Post Tue Apr 15, 2014 9:38 pm
Its to do with that diff pipe you blanked off, the diffs on these have a hydraulic lock, hence the pipe
Post Tue Apr 15, 2014 9:57 pm
to make it act like an LSD? I've cut the sodding pipe. I wonder if i could refit the unit and just this pipe?
Topblag
Post Tue Apr 15, 2014 10:33 pm
Have you been at the twin sunroofs yet ? Had a look at mine today. Front won't even turn manually so I'm assuming the motors goosed. Trying to find a smart way to drop the clutch nut from the rear motor without dropping the headlining.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Post Tue Apr 15, 2014 10:36 pm
Gareth will know more as he has stripped one apart, but yes it locks up for traction
Post Wed Apr 16, 2014 8:58 am
I think what I could do is this, reconnect the diff pipe to the unit. Then the feed from the unit to the pas pump. But I'll need another sls pump! Then I could blank off the feeds from the hydro pump to the bombs. Might aswell keep the diff working as it should
Andyboy
Alpina Colada
Post Wed Apr 16, 2014 6:51 pm
Surely the effort/time/cash expended on this wheeled corpse would finish the C2?
You're getting as bad as Pete for loving a dramafest!
Post Wed Apr 16, 2014 6:53 pm
Andyboy wrote:Surely the effort/time/cash expended on this wheeled corpse would finish the C2?
+1!
Andyboy
Alpina Colada
Post Wed Apr 16, 2014 6:56 pm
It's a fookin illness! :D
Post Wed Apr 16, 2014 7:02 pm
He's worse ! I would never have bought that IX , not without getting the arctic 520 weighed first :)
Post Wed Apr 16, 2014 7:27 pm
pacerpete wrote:I would have bought that IX if I had a spare inch of room to park it
EFA :D
Post Wed Apr 16, 2014 8:34 pm
efa?
Its only money it can always be replaced. Some northerner, scots type will thank me when its snowing!
I've sussed how i can reconnect the remander of the SLS system to get the diff locking again. I just need another SLS pump, opps
The C2 is ongoing, the head is at janspeed being worked on and the pistons are at my old mans machine shop. The rest of the engine is sitting in my garage waiting to go back together! I'm not worried about the rest until the engine is in and running. The stereo and wheel refurb etc can wait.
we all like a sh!theap now and then, this is my one enjoy homos!
Post Wed Apr 16, 2014 8:45 pm
The mrs should be greatful, instead of chasing and barebacking bitches or travelling around the world watching sorry c0cks kicking a ball about , she knows exactly where her Simey is. Underneath an E34 shooting break , for the foreseeable future :)
gareth
Post Wed Apr 23, 2014 12:20 am
Wow, now that's a proper heroic turd! :D
The diff is a LSD, with clutch plates and everything. but it's odd! on a normal BMW LSD, the drive/torque applied to the diff applies a clamping force to the clutch plates to make them lock. On these the force is actually applied with a hollow hydraulic cylinder, fed by that pipe. The traction control senses wheelspin and locks the diff up to control it.
My vote: Whack a hydraulic handbrake somewhere in the boot and connect it to that pipe/the diff. Then you can have winter and summer modes with a simple pull on a lever! :cool:
Post Fri Apr 25, 2014 12:13 pm
Interesting, there is space in the back for such a lever!
I'm getting closer now,
I've changed the rear pitman arms, subframe bushes, discs, drum shoes and fitted the 540i saloon shocks with springs of unknown spec!
Doesn't sit too bad, not too low on the back i think. Theres only one lower spring pad listed for e34's unlike e30's where you can tweek the height. More importantly it doesn't drive like a double bed. It needs a ball joint on the front and suspension wise its ready
Front to rear brake line done.
I'm tackling the fuel lines now, i'm just going to clean up and waxoyl the breather pipe.
hows this for two tone green?
Topblag, the double sunroofs all work ok. I've dropped both motors down and added lots of new grease into the worm drive, gears on the motors. I've also greased up the felt draught excluder around both roofs and the stainless steel runners. This has helped it all greatly and now they both move all correctly in every way you can imagine. Quite a feat they are!
Post Fri Apr 25, 2014 12:43 pm
Top-tastic rescue effort! And to think, I thought my Peugeot 306 Cabriolet drama was bad... :)
Post Fri Apr 25, 2014 12:47 pm
any decent chips for a non vanos M50? it needs help poor thing lots of car and transmission to pull!
Post Fri Apr 25, 2014 12:56 pm
Yes - PM sent.
Topblag
Post Sat Apr 26, 2014 11:25 am
I shall be doing the greasing of the cable and replacement sunroof motors.
I picked up a full working setup the other day. When I say full, it includes the full tray.
Andyboy
Alpina Colada
Post Sat Apr 26, 2014 10:57 pm
I had a bit of E34 moisture today - passed a garge with a white M reg 520i saloon in the front, base model with the flat face basic alloys. A week before I could have had it for 200 quid, but the customer has bitten the bullet for rear sub mounts and fuel pipes.
Post Sun Apr 27, 2014 8:58 am
Rust hunt has found the following, drivers side, nice. the abs pump is right the otherside of this.
plus the bit on the rear passenger sill. These bits done and she should be good :o
Andyboy
Alpina Colada
Post Sun Apr 27, 2014 9:05 am
Welding a la rouge? (cold welding / heatless welding, Hairy Mary etc) :D
Post Sun Apr 27, 2014 9:20 am
no my VW dred locked fried next door is doing it with the mig
He's just finished the e36 on all 4 jacking points for its MOT nice man!
Andyboy
Alpina Colada
Post Sun Apr 27, 2014 3:42 pm
Beetle owners = MIG masters. :D
Post Sun Apr 27, 2014 7:31 pm
Weather permitting thursday friday this week for mig action, he made a nice job on the e36
I swapped the cruise control stalks,
This one is off an e32 and seems a bit saggy like, doesn't fall to hand its a million miles from the wiper stalk.
This has that horrid airbag wheel, am i right in thinking a "tech 3" wheel from and e36 M3 will fit? The nice one
For this e36 one, which seems nicer to my mind
wow, twas a labour intentsive job but both fuel lines changed. They come pre bent from BMW but often and in this case the parts men often add a few extra bends to the pipes to keep you on your toes. I'm hoping some gear on the breather pipe will keep the MOT man happy?
Is this the breather pipe that famously rusts? I guess someone has been kind as it was pretty good but a wire brush and some gear should keep it right. The bumper support however is in major trouble
Huge step forward now it feels with all the lines done, just windscreen, welding and ball joint for MOT. And bleed the brakes up with new fluid. V5 should be coming soon also - i've had a letter saying it would be done by the 28th at the latest and then allow 5 working days for the V5 to arrive.
Post Sun Apr 27, 2014 8:21 pm
You hero ! I have an 850 with some grumpy pipework, when shall I drop it off ? :)
Post Sun Apr 27, 2014 8:47 pm
The MOT tester will just class that breather pipe as a fuel pipe, so it could still fail, wire brush the coont and then brush some copper grease on 8)
Post Sun Apr 27, 2014 9:26 pm
Most kind! June would be best Pete! I've wire brushed it off and coated it in some gear. the important bit is the fuel feel and returns are new in my eyes?
I've had e30's in the past with breather pipes like this and new fuel feed/returns pass ok.
maxfield
Post Sun Apr 27, 2014 9:42 pm
A corroded fuel pipe is only advisory assuming it's not leaking.
Post Sun Apr 27, 2014 10:09 pm
Best to give them a generous coating of dark lithium grease, perhaps with some dirt thrown on for good measure. :wink:
Post Sun Apr 27, 2014 10:10 pm
Depends how corroded. As with many testable items its down to the testers discretion.
Knowing Simons nit pick tester it will fail. :(
maxfield
Post Sun Apr 27, 2014 10:22 pm
It says nothing in the manual about corroded fuel pipes.
To advise them on the MOT computer you would have to go into 'none component related advisorys'
Andyboy
Alpina Colada
Post Sun Apr 27, 2014 10:43 pm
I have a brand new E34 rear tank breather pipe. When it pin holes, it leaks and it wiull drop a LOT of fuel pretty quickly. Worth changing it wiuth the rear bumper off.
Post Sun Apr 27, 2014 11:17 pm
You are correct Jamie, only failable on security, excessively chafed or damaged.
It's brake pipes I'm thinking of.
You started testing now?
Post Sun Apr 27, 2014 11:24 pm
that breather pipe wrapped around the rear of the tank is tbh in really good condition, its much better than the breather pipe that runs with the fuel feed/return pipes.
Barry don't forget we've found a non hitler MOT man now :o Passed the e36 on friday with no advisorys!
