I managed to remove the road wheel and the rear disc
Do I just need to hit it harder,or am I missing something?
Thanks!zd3bx wrote:A couple of videos, might help
Removal >
Installation >
I think that's an E46, but it's pretty much the same process.
Only need to cut across the narrowest part, where the cut out for the caliper is. You can twist it into place and bolt it up before welding.daimlerman wrote:
So this afternoon's job is to slice the new backplate up,bolt it in in two halfs,and then weld the bugger up.
