Evening all,
Im using the 260 gearbox and starter, but when lining up the starter it is pressed up against the block? I dont want to go ahead and bolt it into place as im worried it isnt positioned correct and may cause premature wear on the ring gear.
I have never seen a starter pressed up against the block.
So, are the pre-facelift units any different from facelight?
With the mileage being low, this could possibly be the starter it left the factory with.
Any help greatly appreciated.
Cheers, Ryan.
M52 Starter Motor
rich318i
what flywheel you using??
M52 starters dont marry up with M20 flywheels m20 starters have 9 teeth
ryan_gwa
Im using the M20 flywheel. The start is also M20. I think its the width of the M52 block that is causing the problem.
Question is, are there smaller starters for M20's?
Cheers, Ryan.
Cheers, Ryan.
rich318i
thats not the case they fit !!!
ryan_gwa
I must have the only M20 starter to break the rules! Typical.
shedrool83
ryan_gwa
Even if I could just compare it to mine?
shedrool83
ryan_gwa
Fantastic, cheers!
