M52 Starter Motor
ryan_gwa
Post Sat Apr 05, 2014 10:46 pm
Evening all,
Im using the 260 gearbox and starter, but when lining up the starter it is pressed up against the block? I dont want to go ahead and bolt it into place as im worried it isnt positioned correct and may cause premature wear on the ring gear.
I have never seen a starter pressed up against the block.
So, are the pre-facelift units any different from facelight?
With the mileage being low, this could possibly be the starter it left the factory with.
Any help greatly appreciated.
Cheers, Ryan.
rich318i
Post Sat Apr 05, 2014 11:47 pm
what flywheel you using??
M52 starters dont marry up with M20 flywheels m20 starters have 9 teeth
ryan_gwa
Post Sun Apr 06, 2014 12:14 am
Im using the M20 flywheel. The start is also M20. I think its the width of the M52 block that is causing the problem.
Question is, are there smaller starters for M20's?
Cheers, Ryan.
rich318i
Post Sun Apr 06, 2014 12:22 am
thats not the case they fit !!!
ryan_gwa
Post Sun Apr 06, 2014 12:24 am
I must have the only M20 starter to break the rules! Typical.
shedrool83
Post Sun Apr 06, 2014 7:31 am
Ryan i'm in Dundee and i'll have a m20 starter at the garage if you want to try it incase yours is different.
ryan_gwa
Post Sun Apr 06, 2014 8:37 am
Even if I could just compare it to mine?
shedrool83
Post Sun Apr 06, 2014 2:36 pm
ryan_gwa wrote:Even if I could just compare it to mine?
I'll dig it out and get back to you to see how to get it to you.
ryan_gwa
Post Sun Apr 06, 2014 4:35 pm
Fantastic, cheers!
