Authentic alpina 2.7 engine
whiterhino
Post Wed Apr 02, 2014 10:15 pm
As title says really.how can you tell if an alpina 2.7 engine is authentic.What about the ecu aswell.Will either have distinguishing features.
M3 cecotto ultimate driving machine
Post Wed Apr 02, 2014 10:43 pm
The ECU should have a red Alpina sticker on it, with the model/build number to match the dashboard plaque/chassis plate.
whiterhino
Post Wed Apr 02, 2014 10:50 pm
[quote="Speedtouch"]The ECU should have a red Alpina sticker on it, with the model/build number to match the dashboard plaque/chassis plate.
Speed touch is that located under the dashboard .the car in question is a replica. The owner claims all parts are genuine including engine and ecu.the pictures suggest it is but I'm useless with computers.its on another website.no engine pics tho.
Post Wed Apr 02, 2014 10:58 pm
Yes, the ECU should be in the normal place; just remove the trim panel below the steering column and look up.
It will probably just be a standard 0 261 200 173 ECU with an Alpina chip in it.
Post Wed Apr 02, 2014 11:21 pm
If the block is genuine it will have C2/ then the engine number stamped into it on a flat section of the block bottom on the inlet side.
M-Sport
Post Wed Apr 02, 2014 11:32 pm
Would a c2.5/c2.7 head have any Alpina markings on it?
Rodderz
Post Wed Apr 02, 2014 11:54 pm
An Alpina head will have a 4 digit number stamped into it, on the inlet side, just below where the cam cover sits.
M-Sport
Post Wed Apr 02, 2014 11:58 pm
So most likely the build number Sytner gave the car when Alpina conversions carried out right?
alpina123
Post Thu Apr 03, 2014 9:09 am
2.7 should also have a 6 branch and i know some c2.7 have black inlet manifolds and rocker covers dont know about the 2.5 though
Post Thu Apr 03, 2014 9:13 am
alpina123 wrote:2.7 should also have a 6 branch and i know some c2.7 have black inlet manifolds and rocker covers dont know about the 2.5 though
As above but most of the original alpina 6 branches have rotted out by now and are long gone.
Post Thu Apr 03, 2014 5:20 pm
ALL genuine 2.7 engines had dark grey inlets and rockers. The 4 digit head stamping are done by the man at buchloe who built it. The number on the block on a UK supplied car will read C2 2 then the last 7 digits of the chassis number of the car it was fitted to.
There is another flat section on the block below by the dipstick. Often a 4 digit stamping here also.
Post Thu Apr 03, 2014 6:08 pm
The ECU should also have a label with the last 7 digits of the chassis number on, so you could check that the numbers tally with those on the engine, to be doubly sure you're getting an Alpina setup.
whiterhino
Post Thu Apr 03, 2014 8:30 pm
Thanks for all the input guys.the vendor has sent me a few pics by email.sadly none of the engine or ecu.they are of the seats and various other pics like the wheels and stuff.basically the car is an alpina replica that the vendor claims is all transfered from the donor car.wheels and kit seem spot on.but the engine and ecu are my concern.the car has a btb 6 branch and he says he has a receipt. The car is advertised on car and classic.as you all know my skills on a computer are tragic.maybe one of you even knows the vehicle.theres not many that zoners don't know.
pony2
Post Thu Apr 03, 2014 8:35 pm
whiterhino
Post Thu Apr 03, 2014 8:37 pm
pony2 wrote:Link to the advert:
http://www.carandclassic.co.uk/car/C486777
Much appreicated
Rodderz
Post Thu Apr 03, 2014 8:41 pm
Not all conversions have dark rocker covers or inlet manifolds!
whiterhino
Post Thu Apr 03, 2014 9:40 pm
Look guys feel free to express your thoughts.i actually hope someone knows the car.i have an offer in mind if the engine and ecu are correct.if not I'll hold my folded.im no expert that's why I'm putting out the feelers :D
Post Thu Apr 03, 2014 10:14 pm
I would suggest you check the engine and ECU first, to be sure of what you're getting.
brettski
Post Fri Apr 04, 2014 9:07 am
If the viewings are to take place at an e30 specialists then surely they can show you where the stamps are on the engine?
Post Fri Apr 04, 2014 9:11 pm
Rodderz wrote:Not all conversions have dark rocker covers or inlet manifolds!
prove it, i'd bet money. I've NEVER seen a proper C2 2.7 or B3 2.7 that hasn't left Alpina like it
whiterhino
Post Fri Apr 04, 2014 9:49 pm
Seems nobody knows the car or has much to say about it. You lot usually have lots to say :D
Post Fri Apr 04, 2014 10:05 pm
DVLA vehicel check suggests it's based on a 325i:
Vehicle enquiry
The enquiry is complete.The vehicle details for J781 NWL are:
Date of Liability
01 07 2014
Date of First Registration
01 10 1991
Year of Manufacture
1991
Cylinder Capacity (cc)
2494cc
COâ‚‚ Emissions
Not Available
Fuel Type
PETROL
Export Marker
N
Vehicle Status
Licence Not Due
Vehicle Colour
GREY
Vehicle Type Approval
Not Available
Vehicle Excise Duty rate for vehicle
6 Months Rate
12 Months Rate
£126.50
£230.00
Rodderz
Post Fri Apr 04, 2014 10:49 pm
Mine!
Rodderz
Post Fri Apr 04, 2014 10:51 pm
Bugger! We should have talked money first! :(
hum3
Post Fri Apr 04, 2014 10:57 pm
Simon13 wrote:ALL genuine 2.7 engines had dark grey inlets and rockers. The 4 digit head stamping are done by the man at buchloe who built it. The number on the block on a UK supplied car will read C2 2 then the last 7 digits of the chassis number of the car it was fitted to.
Simon is spot on that's I have known them to be ,I have owned three :D and they all came with black covers n manifold
Rodderz
Post Fri Apr 04, 2014 11:02 pm
Well, it is a fact that they didn't!
e30_mtec
Post Sat Apr 05, 2014 1:36 am
Any one have any info on the car in question?
alpina123
Post Sat Apr 05, 2014 7:17 am
Rodderz wrote:Well, it is a fact that they didn't!
Have you had the car from new? If not they've probably been swapped with a 320 or 325, either that or the whole engine has
Rodderz
Post Sat Apr 05, 2014 6:47 pm
alpina123 wrote:
Rodderz wrote:Well, it is a fact that they didn't![/quote
No I haven't, but, it is the original engine!
Look, do your homework, and you will find that I'm right!
Post Sat Apr 05, 2014 7:56 pm
e30_mtec wrote:Any one have any info on the car in question?
It's a four door. The end :(
alpina123
Post Sat Apr 05, 2014 9:48 pm
We'll how do you know it's the original engine then and how do you know the bits haven't been swapped with a 325i
e30_mtec
Post Sun Apr 06, 2014 12:53 am
All original parts.....
ECU is a pina one...
Not to sure on the engine as i couldnt see the engine number
Proud new owner _--_--_--_
Possibly one of the best e30 iv driven...
alpina123
Post Sun Apr 06, 2014 8:21 am
Did it have a 6 branch manifold
ajay
Post Sun Apr 06, 2014 9:33 am
Funny enough, i know the history on this one, the block has been changed but all the internals and other alpina parts are definatly 100% genuine Alpina, ( engine c2, 2.7 for sure) the seller and previous to him Alpina owner are hiding nothing, its as close to the real thing as your gonna get, it drives and sounds pretty awesome.
jonny323i
Post Sun Apr 06, 2014 10:45 am
Why was the block changed
Touring for life
