The backs lower than it should be.
The sides are lower than the rest of it.
How do I reset my rear bumper and front bumper
jimbom30cab
- Tech 1 freak
if this is a facelift car then the runners the bumper sit on use eccentric holes I think , which can be adjusted to get a neat fit.
jimbom30cab
- Tech 1 freak
take the bumper off and look at the slider brackets at the side, they can be adjusted
jimbom30cab
- Tech 1 freak
For the rear, 2 large bolts - star shaped fittings - under the rear panel
The bit of plastic here?
http://i593.photobucket.com/albums/tt17 ... vqgrav.jpg
Topblag
T55 Torx headed bolts. Soak them in wd40 or similar 24 hrs in advance, try and pull the bolt down as it's being loosened and use a 1/2 drive T55 socket, I broke three 3/8 drive T55s in a month.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
