My cab keeps blowing fuse 17!!!
Flute
Post Sun Mar 30, 2014 8:15 pm
Hi, I have just managed to get my e30 cab on the road. Now I'm finding that it had a blown fuse in slot 17 (electric windows). I replaced the fuse several days ago and it's blown once again.
Any ideas as to the fault, sorry for scant information.
Flute.
Post Sun Mar 30, 2014 8:20 pm
Usual problem is metallic debris inside one of the window switches.
j4gz
Post Sun Mar 30, 2014 8:21 pm
Hi flute I got the same problem I posted and got a few replies on a thread in the week, I replaced my window isolator switch and that solved part of the problem the next I was advised that a green wire off the starter motor could be corroded and may need to be replaced I haven't checked this myself and there are two fuses 17 & 28
Flute
Post Sun Mar 30, 2014 8:27 pm
Thankyou for the fast response gents, I will take a look at those areas tomorrow weather permitting.
Flute.
Post Sun Mar 30, 2014 8:31 pm
j4gz wrote:Hi flute I got the same problem I posted and got a few replies on a thread in the week, I replaced my window isolator switch and that solved part of the problem the next I was advised that a green wire off the starter motor could be corroded and may need to be replaced I haven't checked this myself and there are two fuses 17 & 28
Both these faults will result in no power reaching the windows, but neither will blow fuse 17.
