E36 radiator in pre-facelift chromie
J90rdn
Thu Mar 27, 2014 11:17 pm
Anyone have any advice on how to fit an e36 aircon rad in a pre facelift chromie? Searched and found plenty about mounting in facelift cars, but nothing on chromies.
1987 316 pov spec, upgraded to M52B28
rich318i
Thu Mar 27, 2014 11:35 pm
They fit, its the right mounts you have to get it not that hard
Fri Mar 28, 2014 9:20 am
J90rdn wrote:Anyone have any advice on how to fit an e36 aircon rad in a pre facelift chromie? Searched and found plenty about mounting in facelift cars, but nothing on chromies.
As the mounts are in a different place on a pre-facelift car its not the same, I just space up the rubber feet by about 15mm and put a nut/bolt through them
J90rdn
Fri Mar 28, 2014 10:05 am
I must be missing a shed load of brackets then.
This is how the e36 rad sits at the top - no brackets
This is the bottom of the e36 rad - no brackets
This are the mounting points I have
Fri Mar 28, 2014 12:28 pm
The bottom pic is what I was on about, raise them up to get the rad at the correct height.
Facelift plastic clamp on the top to hold it to the front panel
Kedge
Fri Mar 28, 2014 12:36 pm
My prefacelift has an M20 fitted with an E36 aircon rad, can just make out the clamp Dan has posted in the pic below. I just raised the rad using some old head bolt washers under the rubber mounts but on top of the tabs on the front panel;
Instagram - Kedge85
J90rdn
Ah, so it's just resting on the bottom rubbers?
EBay search for that plastic clamp begins :-)
Kedge
Fri Mar 28, 2014 12:39 pm
Sure is.
Just get a wanted add up on here, should be plenty of breakers with them.
Instagram - Kedge85
J90rdn
Fri Mar 28, 2014 12:44 pm
Cheers guys :-)
One step closer to getting it fired up - can't wait !!!
J90rdn
Fri Mar 28, 2014 1:22 pm
Just ordered one from BMW - part number 17111709347 £5.83
ryan_gwa
Tue Apr 01, 2014 1:19 pm
When you ordered yours, did you get the little rubber mounts too, should be two?
I only ask as im missing one and will probably need to go to the dealers.
J90rdn
Tue Apr 01, 2014 1:39 pm
I'll let you know. It came into the dealers today so I'll be picking it up Thursday :-)
ryan_gwa
Tue Apr 01, 2014 3:11 pm
No worries, cheers.
J90rdn
Thu Apr 03, 2014 2:28 pm
ryan_gwa wrote:When you ordered yours, did you get the little rubber mounts too, should be two?
No rubber bits, just 1 piece of molded plastic.
J90rdn
Wed Apr 09, 2014 12:21 am
Worked out that I too needed the rubber mounts, so had them ordered in as well. Part number 17111150984 x 2 at a cost of £5.60 plus VAT.
Radiator fitted tonight. :D
ryan_gwa
Wed Apr 09, 2014 7:16 pm
Ok no worries, I only need one, thanks for keeping me updated!
