What's the correct battery for 325i cabrio?
jimf
Post Sat Mar 15, 2014 6:20 am
Looking at fitting a Bosch battery for my '87 325i cabrio and ECP list 027's and 096's with varying values. Can anyone tell me which is the correct size please as I can't find a definitive answer online.
jimf
Post Sat Mar 15, 2014 6:30 am
Think I've got the answer from the wiki pages, 096 with 72ah
Gavla
Post Sat Mar 15, 2014 8:53 am
Correct!
Post Sat Mar 15, 2014 9:46 am
096 FOR any E30. With the extra electrics most E30s have on them, the extra capacity is nice to have.
polsta
Post Sat Mar 15, 2014 9:50 pm
Bump on this
Need a battery myself, so its an 096 type , but what AH and CCA size is needed ? Or is it a case of the more the better ?
Anyone know best place to buy from ? Is Bosch the one to go for ? S3 or s4 ?
polsta
Post Sat Mar 15, 2014 9:53 pm
There's Bosch 70-640 for £59, or 74/680 for £10 more ? Can't see a 72
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Mar 15, 2014 10:37 pm
polsta wrote:Need a battery myself, so its an 096 type , but what AH and CCA size is needed ?
jimf wrote:Think I've got the answer from the wiki pages...
polsta
Post Sat Mar 15, 2014 10:57 pm
polsta wrote:There's Bosch 70-640 for £59, or 74/680 for £10 more ? Can't see a 72
Grr the wiki says 72 640 , but nothing about if a 74/680 can be used or not ? Does it make any difference or does it mean its the same just a bit more powerful ?
Grrrmachine
Post Sat Mar 15, 2014 11:06 pm
The wiki says 680. You've found a battery that has 680. I'm not sure what the issue is here.
polsta
Post Sat Mar 15, 2014 11:11 pm
The 72AH and the 74AH
Grrrmachine
Post Sun Mar 16, 2014 8:23 am
Nah, unfortuantely those two extra amps will cause your alternator to explode and the engine bay to be engulfed in flames. You'll have to keep looking :wink:
In all seriousness, you don't have to get batteries absolutely perfectly matched.
Post Sun Mar 16, 2014 10:17 am
You can use any battery that puts the terminals in reach of the leads that physically fits and can be secured in the battery position!
If you want one that will start the car after you've left the lights on overnight, or parked up for a couple of hours with the radio on, then fit an 096.
