MOT Brakes - Only just passed
RobWill116
Post Wed Mar 12, 2014 12:32 pm
Hi all,
Had MOT recently and the guy said that it only just passed on the brake roller tests and the handbrake tests.
I checked all the brake components before MOT and the discs and pads are only about a 1/4 worn. The handbrake shoes looked in good condition too.
What else can I look at? When driving it certainly stops fine for me so not sure why it only just passed.
Post Wed Mar 12, 2014 1:13 pm
Perhaps they need bleeding...
Rtaylor2208
Post Wed Mar 12, 2014 1:29 pm
The handbrake will need adjusting through the hole in the disks not at the cables inside which is an easy job and covered in the wiki.
Rtaylor2208
I am assuming yours is a rear disc setup.
Post Wed Mar 12, 2014 2:08 pm
Are you saying the normal road brakes only just passed, or just the handbrake?
The braking requirements for the foot brakes required by a MOT test are very low, bordering on dangerous, and any near failure needs urgent investigation.
There are well known reasons for BMW handbrakes being poor, usually as a result of incompetent servicing.
