E30 318i touring track rod remove
ThreeDLee
Post Wed Feb 26, 2014 4:28 pm
I have manage to get the ball joint out away from the wheel but I can't remove it from the adjuster part as its rusted... I need to replace the whole lot but don't have a tool for the other end that inserts into steering rack, what else can I use?
Thanks, lee.
mcbonio
Post Wed Feb 26, 2014 4:59 pm
A big crescent wrench will get the steering rack end off.
G-Bear
Post Wed Feb 26, 2014 7:04 pm
No special tool needed as far as I know.
Just carefully bend the retaining tabs of the washer from out of the slots in the steering rack. The get mole grips or grip lock pliers on the two flat sides near the ball joint of the rods where they meet the rack and turn them off.
Set up the new trackrods to match the same in length as the old ones then get them tracked properly.
ThreeDLee
Post Thu Feb 27, 2014 7:30 pm
thanks guys! i got some mole grips on the shitter...
harry_p
Post Thu Feb 27, 2014 11:06 pm
On an e36 the inner joint to rack uses the same spanner size as a viscous coupling. I would imagine an e30 is very similar. I did have to extend it a bit with a pole because they're damn tight :D
cheers,
harry
ThreeDLee
Post Sun Mar 02, 2014 12:45 pm
i had to use me leg to push the mole grips!
Post Sun Mar 02, 2014 1:12 pm
Stilsons!!!! Or the viscous spanner.
