17" Alpina's or 17" Motorsports?
nickso
- Location: Go do that voodoo that you do so welllllllll!!
Neither, 17" is too big.
'88 e30 328i M52 track bint.
Aids or bum cancer
Neither?
harry_p
Both are cheap Chinese crap.
cheers,
harry
harry
Fastroad
Not sure which question takes more thought.... My answer would be neither for both questions.pacerpete wrote:Aids or bum cancer
For the wheels why not stay original ?
assassin
F*ckit. You want to run 17's, do it .Its your car. Be happy with YOUR choice, not what some other self righteous **** thinks you should do. Customising/rodding was around before most people on the zone were born. Do what YOU want, not some other.......person.
polsta
That actualy made me roar with laughter !! Brilliantpacerpete wrote:Aids or bum cancer
polsta
Do what you want of course, but 17"s on an e30 do ruin the drive, and unless you sort the camber at the back the inside of the tyres get eaten rapidlyassassin wrote:F*ckit. You want to run 17's, do it .Its your car. Be happy with YOUR choice, not what some other self righteous **** thinks you should do. Customising/rodding was around before most people on the zone were born. Do what YOU want, not some other.......person.
jmc330i
Only if the car is lowered, which will be the same regardless of wheel size.polsta wrote:unless you sort the camber at the back the inside of the tyres get eaten rapidly
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
harry_p
Camber seems to wear out lower profile tyres quicker as there's less flex in the sidewall to let the tyre fold flat against the road.
My m3 seemed to wear the inside of 17s a lot quicker than higher profile 16s
cheers,
harry
harry
harry_p
Which is fair enough, but why did they come and ask for advice in the first place.assassin wrote:F*ckit. You want to run 17's, do it .Its your car. Be happy with YOUR choice, not what some other self righteous **** thinks you should do. Customising/rodding was around before most people on the zone were born. Do what YOU want, not some other.......person.
Both 17in alpinas and 17in motorsports are cheap crappy replicas of decent wheels.
If the original poster wants to fit 17s I'm not going to get my knickers in a twist, but I'd advise afainst fitting cheap rubbish ones.
cheers,
harry
harry
polsta
There's probably not an e30 with 17" alpinas that isn't also lowered !jmc330i wrote:Only if the car is lowered, which will be the same regardless of wheel size.polsta wrote:unless you sort the camber at the back the inside of the tyres get eaten rapidly
jmc330i
polsta wrote:There's probably not an e30 with 17" alpinas that isn't also lowered !jmc330i wrote:Only if the car is lowered, which will be the same regardless of wheel size.polsta wrote:unless you sort the camber at the back the inside of the tyres get eaten rapidly
James
'91 325i Sport
'91 325i Sport
