Induction kit, please help!!
Johnboy83
Hi, I have a 325i touring and need some advice, is It worth putting an induction kit on it not? If so which one is worth doing? I want to eventually change the exhaust to a scorpion system but have no idea regarding the induction kit??[/img]
dusty23
if you want to lose power get an induction kit and if you want lose more power buy a scorpion exhaust.
If you just want your car to sound excessively loud and don't care thats its slower do both of the above
1988 M3 lachs silver S50B32
1989 325i sport delphin grey
1993 316i lux touring lazur blue
Johnboy83
Seriously are they both that bad?
dusty23
Yes in a word, the only gain from an airbox upgrade would be some kind of cold air/forced induction but it is pricey and the gains aren't that great.
The scorpions also are not good, shit steel etc.. better with the standard.
if you want more usable power get a chip off a member called speedtouch on here.
JF008
Some free flow air filters and after market exhaust can show marginal gains. You need to shed some serious dollars tho. Ram air crap and other cheap halford's type air filters won't do anything good IMO.
JF008
http://www.turnermotorsport.com/BMW-E30 ... lters.aspx
''Advanced Flow Engineering (aFe) makes these high performance, high flow OE air filters which replace the restrictive factory paper filter and lets your engine breathe better. These are stock replacement filters that drop in to your BMW's factory airbox system, and will increase flow to the engine, yielding more horsepower and torque. ''
As for exhaust, quality tubular manifolds would be a bettter buy than an exhaust for hp gains I think.
Johnboy83
Would a back box make any difference?
dusty23
Not really, if you want drop some cash get this
http://www.racecar.com/bmwexhausts/newse30exhausts.htm
dusty23
Johnboy83
Cheers and I am quite surprised!! Any ideas as to how much the manifolds are?
dusty23
A lot! Can't remember exact figure think around £800 maybe more.
Seriously though try this first
http://www.e30zone.net/modules.php?name ... sc&start=0
Johnboy83
I think this is the route I will go down, thanks for all the replies. I don't want to be doing loads to the engine and wanted it to stay a bit standard.
