1987 Baur 318
Im trying to wire up a radio and have come across four wires all together and are coded like such;
purple/white
red/white
brown
red/green
Now I belive the brown to be earth but can not find a live feed with 12v only one giving out a strange 2.5 v
The analogue clock does not work but I can only find again this 2.5v with the meter.
I`ve looked at different wiring diagrams and can not seem to see these wires and also the speaker wire clours are very different too.
I hot wired my old London radio with another power source ,connected up all four speakers and they all worked fine, even the cassette.lol
Any ideas on the 2.5 volt situation please?
Cheers Mart.
Low Voltage ?
beemerbird
Mart, at a guess, is the 2.5v to do with a permanent live to maintain your radio station settings etc? Terrible to respond to a question with a question, I know........
Right now Fi I was looking for any live and found this strange voltage so I was rather hoping to find more than one.
BenHar
The radio loom should come from the accessory socket behind the glove compartment.
http://www.e30zone.net/e30zonewiki/inde ... ory_Socket
Ben
Ben
The red/green is the permanent 12 volts live, and comes from the same fuse as the clock (#21), so I suggest you replace this fuse. Only a short length of wire between the fuse and the accessories socket, so there's not a lot else it can be.
Purple/white is the switched 12 volts+.
Your red/white is probably actually grey/red, and is panel lights.
thanks alot for advise .
Update !!!
The old school "London" is up and operational, the analogue clock is reporting the correct time and as a bonus the rev counter has started to work for the first time since I`ve had her .
Many thanks for all your help.
Cheers, Mart.
Cheers, Mart.
BenHar
So what was the problem? In case someone else has the same.
Ben
Ben
Fuse 21 mate.
