m3 s50b3.2 wireing
321gazza
Post Sun Feb 09, 2014 8:35 pm
fitting above engine into my e30 318i and also one into my opel manta gte,, in my manta i have no way of supplying a speed signel for the ecu, the wireing of the m3 engine will be complex for a very basic car so could anyone on here help me out orshould i go standalone management for the manta, i do have all the info for the bmw so will test you clever guys some what.
Post Sun Feb 09, 2014 9:29 pm
Should be simple enough to simulate a (fixed) speed signal to keep the ECU happy.
321gazza
Post Sun Feb 09, 2014 10:04 pm
How could i do that.
Post Sun Feb 09, 2014 10:10 pm
I expect the signal is a square wave of some sort. 'Scope what's on your other car, and build a simple generator to replicate it.
A lot of LPG conversion ECUs have a built in square wave generator to simulate a correct lambda sensor signal to keep the engine ECU happy.
Post Sun Feb 09, 2014 10:26 pm
I dont think the S50 needs speed signal, ive worked on a few E36's where either the wires have been missing or the speedo hasnt been working at all and it hasnt caused any running problems
321gazza
Post Sun Feb 09, 2014 11:02 pm
hope i could run it without a speed signal because i am using stack display system for most of my engine, speed info, so what wires do i need to make the engine run with out a dash, speed signal ect.
321gazza
Post Tue Feb 11, 2014 8:52 pm
Anyone know exactly what wires i need to power up to get engine to run.
Post Tue Feb 11, 2014 9:24 pm
Big red to battery +, big brown or brown/orange to earth, ignition switched 12v+ to green, 12v+ starter switched to brown/yellow, green/purple is power out to the fuel pump, and the EWS gubbins will also need powering up.
321gazza
Post Tue Feb 11, 2014 9:51 pm
Thank you for the info, will give that a try soon on my next day off in a month or so.
