It is finished in cosmos black and champagne leather. I’ve had the car coming up a year and this is what’s been done so far.
Once the car was back home Barry was commissioned to do a full inspection 2
With this then done we also changed all the power steering lines, clutch, gearbox seal, all diff seals, rear beam bushes, front disks, throttle cable, x4 Goodyear tyres and wheel alignment. Car was put to daily use and after a while a yellow inspection light appeared so was given an oil service. Everything has been done using OEM BMW parts ”“ have receipts. Car has been in storage for 3 months now. 4 lights remaining
The car runs a bilstein b12 setup with adjustable front mounts and ground control rear mounts. Other than that it’s entirely standard. Apart from the head unit, this is an alpine number which connects and controls your iPhone
Aircon has been removed
Viscous fan has been removed
Fog lights have been removed
She’s quite stealthy with model inscription delete x2 on the original spec sheet. Boot Badge \ Side Mouldings ect.
Is great fun to drive, very very easy to get wrong side off 100mph ”“ 3rd and 4th gear will get you in a lot of trouble if you’re not careful. However you’ll be grinning like a goodun, the S50 makes the most delicious noise. Sounds so nice when changing gear. The rev’s fall perfectly when you put the clutch in unlike the E30 which seem to hang and gradually reduce back down. The E36 M3 zips down as fast as it raises. I wonder if it is due to the lightweight flywheel on the E30? Mmmm
Anyway, she’ll be getting detailed soon and then up for sale. It’s been a great car to own and, more importantly, drive.
Looking dirty
