new monster v8 no 4.0 here !!! Start up vid on page 28 :)
duracel79
Thu Jan 30, 2014 12:46 pm
ross2009 wrote:I think it's right as it is and plus if I correct it my tyres will rub on the wing so I've decided not too :)
But when you want to set up for traction at the pod with Mickey T's it may of been useful.
ross2009
Thu Jan 30, 2014 12:51 pm
I ain't got much room for my tyres let alone Micky t's
lol
Turbo M20
v8 project 6.0 twin turbo
ross2009
Thu Jan 30, 2014 6:06 pm
well I picked the block up today and got straight on to cleaning it
bought my self some nice cleaning brushes
and got some assemble lube to built it too
got the cam bearings in
what it started like
after alittle clean
and then started the out side
just got to give it a lick of paint now but I'll do that tomoz :)
let the fun begin. :mad:
Turbo M20
Thu Jan 30, 2014 6:11 pm
Looking good. :P
ross2009
Thu Jan 30, 2014 6:32 pm
I still can't fit the crank etc as it's gotta go to be balenced along with all of the rotating assembly so all I can really do is fit the cam :(
Turbo M20
Jamie8GTi
Thu Jan 30, 2014 7:09 pm
that would make a beast of a coffee table!
ross2009
Thu Jan 30, 2014 7:11 pm
i think an ali block would be better suited lol this thing is quite heavy lol
when you nipping over then :)
Turbo M20
Jamie8GTi
Thu Jan 30, 2014 7:15 pm
how much do they weigh fully assembled? I've got to come and see it when its done for sure!
Would like to pop over in mine when its finished but the deadline just gets pushed back more and more the deeper I dig and the more parts she needs ha ha
Love this thread though! must be adding up now
:mad:
ross2009
Thu Jan 30, 2014 7:20 pm
All of the gen 1 small blocks from 1955 up weighs in at 575 lbs with iron intake and heads. thats about 260 kg
Alum. intake drops weight to about 540 lbs, alum heads drops weight to about 500 lbs, mini starter installed drops it down to 490-492 lbs is about 220kg so im saving weight all the time but still a right lump lol
i dont really worry about the money thats not why i do it. its some thing i like doing building engines and stuff making things
yeah come over and have a butchers :)
Turbo M20
jonesy318
Thu Jan 30, 2014 7:30 pm
This is gonna be a beast when done, top stuff.
Jamie8GTi
Thu Jan 30, 2014 7:34 pm
christ mate! what are you doing upfront suspension/brake wise I thought my m50 was heavy haha!!
I'd love to eventually swap in the 2.8 crank, rod and pistons when my cars up and running but I'm no engine builder!! :(
I think I need to just to believe it!
ross2009
Thu Jan 30, 2014 7:37 pm
jonesy318 wrote:This is gonna be a beast when done, top stuff.
thanks dude :)
Turbo M20
ross2009
Thu Jan 30, 2014 7:38 pm
Jamie8GTi wrote:christ mate! what are you doing upfront suspension/brake wise I thought my m50 was heavy haha!!
you not seen how mine car is set up ??
Turbo M20
Jamie8GTi
Thu Jan 30, 2014 7:39 pm
I never saw the original build thread! looks nice from the pictures though.
ross2009
Thu Jan 30, 2014 7:41 pm
Jamie8GTi wrote:I never saw the original build thread! looks nice from the pictures though.
check it out
Turbo M20
Jamie8GTi
Sat Feb 01, 2014 3:26 pm
Cant wait to see this done now!!!!!!!!!!!! :D
ross2009
Sat Feb 01, 2014 5:31 pm
lol told ya didn't i
well done a little more on it today
fitted the arp mains
and gave it a lick of paint
Turbo M20
ross2009
Sun Feb 02, 2014 4:47 pm
as you might have noticed on previous pics i took the anti roll bar out as there is no room for it behind the subframe due to this engine having a rear deep sump unlike the m20 which is at the front
so i thought and done some research the only thing that is some what near to a e30 is a e36 i looked at lots of pics of them and noticed they have a nice cranked down section to clear the sump but this still wasnt going to work on the rear as the cranked section hits the wishbones so theres only one other place for it
put it on the front........ of corse it will have to have some sort of mounting made for it but as you can see it fits pretty well
please ignor the bulk head :roll:
as ive found that the e36 arb is not as wide as the e30 not by much
the bushes dont quite line up with the chassis so im going to have to make some box mounts for the bushes to sit on but have them angled in slightly
but i cant see any reason why it wont work it doesnt fowl on anything so looking good to be
ive also took the engine mounts off and drilled the chassis alittle bigger as im going to weld 2 14mm tubes in the chassis for the bolts for a bit of strength other wise i could imagine the engine pulling them thro at some point and im also going to weld the mount to the chassis rail for abit more strength ive got the material on order so ill update this later in the week when thats done
just a coulpe more bits i done today fitted freeze plugs and oil gallery plugs on the block after paint is dry
still have to fit the rear ones but cant do that till engine is off the stand
Turbo M20
ross2009
Tue Feb 04, 2014 6:04 pm
I've decided to do away with the drop links too and bought some nice rose joints instead wernt cheap mind
Turbo M20
glenn
Engine Transplant Services
Tue Feb 04, 2014 7:07 pm
I had planned to do the same as you ross with the arb.
I kept one here off an e36 m3 evo I had broken, some time ago.
the deep crank in the arb suited my sump too.
ross2009
Tue Feb 04, 2014 7:10 pm
yeah well tbh the cranked bit wouldn't really matter if it wasn't there mounting it on the front as my sump is pretty flat at the front but I think it will work quite well
Turbo M20
ross2009
Wed Feb 05, 2014 8:41 pm
well got the rear core plugs in tonight
and fitted the cam I used the pulley to help fit it as it's something to hold onto while sliding it in
nice bit of lube
cam going in
and it's In
easy as that :)
Turbo M20
Wed Feb 05, 2014 10:44 pm
Looking good. 8)
ross2009
Thu Feb 06, 2014 8:48 pm
getting there slower than i wanted but cant be helped next plan is to get the clutch sorted so i can send the rest aay to be balanced as he needs a pressure plate
i know a guy that knows a top guy in helix clutchs hes going to make me a custom clutch 10.5'' diameter 8 mm thick plate and a pressure plate up to 3000lb clamping pressure it will be made with the supra centre section for the spline and chevy outer and even tho its going to be running alot of hp he believes i can get away with a organic friction plate with it being think and the clamping force of the pressure plate
the whole lot being custom made is 350 quid which i dont think is a bad price
Turbo M20
Jamie8GTi
Fri Feb 07, 2014 10:52 am
For the work involved that's a bargain!??? You know the right people Ross :D
ross2009
Fri Feb 07, 2014 11:23 am
Jamie8GTi wrote:For the work involved that's a bargain!??? You know the right people Ross :D
you have to in this game mate lol
like they say it's not what you know it's who you know ;)
Turbo M20
manse73
Sat Feb 08, 2014 11:39 am
i had a vision
bruv chariots rule
ross2009
Sat Feb 08, 2014 12:01 pm
lol not quite kev :)
Turbo M20
manse73
Sat Feb 08, 2014 12:32 pm
Faster?
bruv chariots rule
ross2009
Sat Feb 08, 2014 1:21 pm
that's set up for drag racing mine won't be lol
Turbo M20
ross2009
Sun Feb 09, 2014 3:46 pm
well although I've been feeling pretty bad this weekend I've dragged my self up the garage and done some work
managed to get the chassis ready for the engine mounting points I've welded the tubing in the chassis to give it some strength
also got the engine mounts finished
also finished the new mountings for the e36 front anti roll bar fits quite nice
Turbo M20
Jamie8GTi
Sun Feb 09, 2014 6:31 pm
nice job ross!
ross2009
Sat Feb 15, 2014 7:03 pm
well seeing as i keep moaning about the rain i thought id do some thing about it ................ my solution
now as thats done and the front anti roll bar is all done i thought id start to tackle to rear first things first get the grinder out
no going bk now after undoing the drive shafts and taking the diff out i started to cut the rear cross member out that holds the diff cover
with the cross member out
and started to clean the pads up where the new cross member will be attached
but sods law i ran out of gas for the welder so will have to wait till monday now to get some more
im going to fit the new diff first to get the correct postion for the cross memeber first them the whole rear beam will come out and be swapped for my new one
more fun and games :mad:
Turbo M20
ross2009
Sun Feb 16, 2014 7:56 pm
continuing from yesterday i got the new diff in its all mock up at the mo so it will all come back out and be done properly at a later date but here the beast in question
one on the left is the medum case one on the right is a large case from a e28 m5 3.07 ratio lsd
this is a big lump i can tell ya
well got it bolted up to the exsisting beam to start with so i can get the new cross member mocked up before i take it all out
and like normal ran into the first problem not thinking that my great idea of using a rear cover from a 750i wouldnt work it dont shit
well saying it dont, it fits, bolts straight on crown wheel is fine but the speed sensor fins are too big where the speed sensor slots in,on the new cover its machined flush with the bolt face,on the original cover the hole for the speed sensor is pulled bk by about 10 mm so it looks like this when bolted on
so what to do i could cut out the old location on the old cover and get it welded in but that would just make a mess so ive decided im going to make a 10mm spacer to pull the whole cover bk 10mm out of a sheet of ali so cant do much more on that till the material arrives
anyway that still didnt stop me cutting things ready for when its sorted
no more commentry ill let ya just look at the pics 8)
im still debating on wether to put the drop links behind the cover or in front
Turbo M20
Phill172
Mon Feb 17, 2014 10:08 am
Fancy doing another rear end like that one mine!?
Following this as thats exactly what i need to do, so are those drive shafts shortened e28 ones or customs
