Which air filter will fit weber carb?
Junglistjed
Post Wed Jan 15, 2014 12:20 am
Basically i got my weber carb fitted and the original air filter didn't fit back on as there wasn't enough clearance between it and the bonnet, if there an alternative that will fit?
cheers
wullie325i
CAUTION - unreliable trader!
Post Wed Jan 15, 2014 12:45 am
k+n used to do them thats what i used on my old 316
Automaton
Post Wed Jan 15, 2014 5:00 am
Maneesh
1986 E30 M10 316 Manual Schwarz Chromie
1982 E28 M20 520i Henna Rot - Project
1988 E32 M70 750iL Schwarz - MASSIVE Project
1991 W201 190e Automatic Schwarz - Sold
1991 W201 190e Automatic Silver AMG Tribute - Sold
1993 E36 M40 316i Manual Brillantrot (RIP: rotting in peace)
Join other Carb Fanatics: E30 316 Carb - The Faithfuls https://www.facebook.com/groups/444263742439145/
Post Wed Jan 15, 2014 10:18 am
Original filter should fit. I've had two with Webers, and neither had problems with clearance.
Junglistjed
Post Wed Jan 15, 2014 3:39 pm
Any idea why mine has problems with fitment? it was fitted by an old car mechanic so i doubt he fitted it incorrectly :/ i think the main problem was that there was nowhere for the filter to screw onto the carb..?
cheers
Junglistjed
Post Wed Jan 15, 2014 4:01 pm
Heres some pictures if they help?
Post Wed Jan 15, 2014 5:23 pm
That phenolic spacer between the carb and manifold looks rather thick. Could you not get a thinner one, then you may be able to fit the standard air filter?
Junglistjed
Post Wed Jan 15, 2014 5:25 pm
Im not sure mate, know nothing about the carb! the mechanic did say it has been modified which made it too too tall?
can anyone confirm if i can buy a different phenolic filter? would save me some cash!
Post Wed Jan 15, 2014 5:30 pm
The carb looks standard, however, immediately below it there is a thick alloy plate holding the cable, and then the rather thick phenolic spacer.
You can buy thinner ones:
http://www.ebay.com/bhp/weber-spacer
Junglistjed
Post Wed Jan 15, 2014 5:32 pm
The black thing inbetween the carb and the manifold? is it thicker then normal?
I bought this second hand so no idea why someone would have a large spacer that would cause the original filter not to fit?
Post Wed Jan 15, 2014 5:39 pm
Yes, the black spacer. Measure it, and find out how thick it is.
I'm sure you could lower the carb by around half an inch or so, using the right combination of spacer(s).
In fact, maybe you could remove the black spacer altogether, and just use the thick alloy throttle cable plate to do the job instead, with a gasket each side of it.
Junglistjed
Post Wed Jan 15, 2014 5:45 pm
Alright mate ill do that, ill also ring the mechanic to see how close the filter was from clearing the bonner.. hopefully this will sort it!
thanks bud, i really couldn't figure out what was causing it to be so high until the mentioned the spacer, i thought it was a necessity.
Post Wed Jan 15, 2014 5:52 pm
Yes, some sort of spacer is required, but yours appears way too thick - the carb retaining nuts are barely able to fit on the mounting studs!
Junglistjed
Post Wed Jan 15, 2014 5:55 pm
Would shaving the spacer down not be a possibility? also, what size spacer would you recommend mate?
Post Wed Jan 15, 2014 5:57 pm
Yes, you may be able to shave it down. I would go for a 1/4 inch thick one.
