As per title. Have an M52B28 I bought from a forum member a while back thats just about to go in. Have been stripping it down and cleaning. The air-con is long-gone, assume removed from pervious owner. All that remains is the pulley. Can this also be removed? If so, is it just a bolt off job?
M52B28 AC Pulley - Can it be removed?
J90rdn
Motorhole
PAS Pulley? Yeah, it's held on by three bolts. 10 or 12 mm iirc. Stop the pulley from rotating by holding one bolt with a spanner whilst loosening another with a ratchet. Loosen all three in turn, then remove them all completely. You may need a bearing puller to remove it from the spigot.
J90rdn
Sorry, talking bollox - AC pulley. Post edited.
jmc330i
The whole AC bracket can be removed, then you just need a shorter non-AC belt to run the PAS, waterpump etc etc.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
J90rdn
Yep, thats all been done, just the pulley left on the crank. Question is can this also be removed?jmc330i wrote:The whole AC bracket can be removed, then you just need a shorter non-AC belt to run the PAS, waterpump etc etc.
jmc330i
Ah, I got you.
I just left the pulley on mine.... kept thinking it could be used to drive something useful, like a supercharger
James
'91 325i Sport
'91 325i Sport
