Hello,
I have a hardtop for my E30 but have found you need a special tool to attach the hardtop to the body.
Does anyone know where you can find these tools? Or failing that does anyone have any useful tips for attaching the hardtop?
Hardtop tool
may be worth asking z3i as hes got a hard top morsel fest going on
http://www.e30zone.net/modules.php?name ... wforum&f=6
Topblag
Is it the tool to tighten the nut on the hardtop pin or the hardtop pin itself ?
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Topblag
Z3I is your man, he used to keep spares. I got mine from him, with a hardtop.
I'm pretty sure it is a 11mm for the top nut which locks the pin in but the tool you need is this one in the link http://www.ecstuning.com/BMW-E30-325is- ... /ES157785/
Thanks for all the help! If a pair of water pump pliers does the job then il try that, I'm not going to use the hard top often so seems a waste to pay £30 for one, there are plenty of parts I could use the money more wisely on, like it needs an alternator as the battery isn't charging well, a Bosch one will set me back £50.
