Hello,
I have a hardtop for my E30 but have found you need a special tool to attach the hardtop to the body.
Does anyone know where you can find these tools? Or failing that does anyone have any useful tips for attaching the hardtop?
Hardtop tool
polsta
may be worth asking z3i as hes got a hard top morsel fest going on
http://www.e30zone.net/modules.php?name ... wforum&f=6
Topblag
Is it the tool to tighten the nut on the hardtop pin or the hardtop pin itself ?
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Matty30
BenHar
Water pump pliers.
Ben
Ben
Topblag
Z3I is your man, he used to keep spares. I got mine from him, with a hardtop.
BenHar
You only need to adjust the nuts once, when you first fit it.
Not worth getting a special tool when water pump pliers do the job.
Ben
Ben
Gavla
BMW do them or you can find some variations on fleabay...
vytas85
If i have good memory on my last ex cab e30 for hardtop lock and unlock i use 13mm round head spanner and it's work perfect
j4gz
I'm pretty sure it is a 11mm for the top nut which locks the pin in but the tool you need is this one in the link http://www.ecstuning.com/BMW-E30-325is- ... /ES157785/
TPS
I've got one of those tools, it's a half moon shape thing, I got it from the dealer
Matty30
Thanks for all the help! If a pair of water pump pliers does the job then il try that, I'm not going to use the hard top often so seems a waste to pay £30 for one, there are plenty of parts I could use the money more wisely on, like it needs an alternator as the battery isn't charging well, a Bosch one will set me back £50.
