front shocks
chopper
Post Fri Dec 27, 2013 3:41 pm
Need to replace my front shocks but don't know what size I need, it's a m20b25 convertible 1989. I thought it would be the 51mm insert?? Thanks in advance
jimmyspeed
Post Fri Dec 27, 2013 3:47 pm
all 325s had 51mm
chopper
Post Fri Dec 27, 2013 3:48 pm
Nice one
harry_p
All 325i should have the 51mm struts.
cheers,
harry
jimmyspeed
Post Fri Dec 27, 2013 3:54 pm
no worries,
if you're having trouble removing the old collar from the top of the shock , cut a small notch in the collar with a grinder/hacksaw. Then place it in a vice , put your chisel/crappy screwdriver in the notch and smash it with a hammer - job done
oil should be in the base of the old leg, so be careful when you remove it
replace the oil if you are using a standard damper, it helps aids cooling and stops it sticking
if you are using a gas dampers no oil is required
Andyboy
Alpina Colada
Post Sat Dec 28, 2013 10:39 am
Gas dampers also use oil for damping, and a bit of neat antifreeze is very good for transferring heat from the dampers to the strut body. Best tool for getting the collars off without butchery is Stilsons and a trolley jack handle.
chopper
Post Sat Dec 28, 2013 12:18 pm
Thanks guys
TPS
Post Sat Dec 28, 2013 9:47 pm
jimmyspeed wrote:no worries,
Thats good advice, Not recommended, but I only way I got the collar nuts, undone by using welding gas, what a PITA to get undone that was!!
