Any info would be very much appreciated
Many thanks
Will that then make it a 3.0 are those internals strong? What sort of power can they handle?wullie325i wrote:use m54b30 crank rods and pistons they fit in the m50 block
M50B30Twullie325i wrote:making a 3l m50b30
Ok thats great. Would you say this is a better route than using the S50 internals and if so why just so i understand?wullie325i wrote:a standard m54b30 is around 230bhp but in an m50 engine they seem to make more due to bigger inlet manny on m50b25 engine. i would say with a blower strapped to it 400-500bhp could be achived.
Because it uses a MAF sensor as opposed to a MAP and it's not tuneable enough. You can use to standard ecu up to around 300-350hp iirc still using the MAF, then it runs out of steam.Paulcl09 wrote:Also can you explain why the original management system can't be used as my friend just keeps asking why. Im crap on this side of things.
