Project Frankenstein. . { 320i auto to 335i manual }
Post Wed Dec 04, 2013 9:01 pm
polsta wrote: BUT - before going gun-ho with the waxoyl , remove that fuel like metal pipe cover thing from rear drivers side arch !!!! vital , clean any crud from behind it AND SPRAY IT THE SAME COLOUR AS THE CAR!!
Cypriotgeeza
Post Wed Dec 04, 2013 9:19 pm
Will do!
No rush as in this situation it is not my daily! back when i had my iS i couldnt do in depth things like this as i had to use it for my daily commute!
Ill prob do it hammerite black :cool:
Check my M30 build threads:
New Daily : viewtopic.php?f=34&t=285452
Cypriotgeeza
Post Thu Dec 05, 2013 9:02 pm
came to a bit of a standstill today, :( i dont know how the weather was on everyones part of the country but the winds down here were crazy! :mad:
i jumped in the beast and tidied up the interior wiring / ground back the rust on the inside corners and there is nothing to report! nice and clean and ready for the Fertan i ordered today 8)
Then it started raining and with a hood as badly split as mine that was my que to cover her up again untill tomorrow (hopefully)
Post Thu Dec 05, 2013 10:37 pm
Those screws were probably for the brake disc - some lazy/forgetful mechanic probably put them there then forgot to put them back in the hub.
Cypriotgeeza
Post Thu Dec 05, 2013 10:50 pm
Speedtouch wrote:Image
Probably! I wonder how long they have been there lol
jimbom30cab
Tech 1 freak
Post Thu Dec 05, 2013 10:56 pm
very very clean , nice buy :D
Cypriotgeeza
Post Thu Dec 05, 2013 10:59 pm
jimbom30cab wrote:very very clean , nice buy :D
Thank you! :D
Post Thu Dec 05, 2013 11:01 pm
Firstly, they are not brake disc bolts, E30 ones are 5mm hex not cross head.
Secondly, why on earth would a "lazy mechanic" put them under the carpet?
Cypriotgeeza
Post Thu Dec 05, 2013 11:04 pm
in all fairness they look like mini disc bolts to me!
Under the carpet is what baffles me..unless the carpet was out previously but there was no evidence to suggest it ever was :?
jimbom30cab
Tech 1 freak
Post Thu Dec 05, 2013 11:06 pm
Those "machine screws" (make a note of that Barry) , i'm pretty sure are not from an e30
Post Thu Dec 05, 2013 11:22 pm
Indeed, they look very much like Mini or Morris Minor ones - is the thread Imperial, or Metric, do you know?
Cypriotgeeza
Post Thu Dec 05, 2013 11:24 pm
Speedtouch wrote:Indeed, they look very much like Mini or Morris Minor ones - is the thread Imperial, or Metric, do you know?
ill pull them off tomorrow and clean the thread lol
Post Thu Dec 05, 2013 11:53 pm
My guess is is that they are something to do with the audio equipment. The electric aerial (of which that red/white wiring is for) comes with brackets and similar screws.
They may have been left over when the aerial was fitted and somehow ended up under the carpet as the wring for the aerial passes underneath from the head unit to the boot.
Cypriotgeeza
Post Thu Dec 05, 2013 11:56 pm
sounds plausible!
Better than finding a bag of weed behind my steering wheel badge in my old iS i guess.. :mad: :mad:
Post Mon Dec 09, 2013 7:36 pm
Pictures not working? :(
Cypriotgeeza
Post Mon Dec 09, 2013 10:40 pm
ImysE30 wrote:Pictures not working? :(
should be sorted now bro :thumb:
Cypriotgeeza
Post Mon Dec 09, 2013 10:45 pm
Finally got this through the post today 8)
Will be unleashing this stuff asap..hopefully bit by bit everynight this week, if not saturday /sunday
Also ordered some underseal at work :)
Post Mon Dec 09, 2013 11:01 pm
I would not be using that black schutz.
Cypriotgeeza
Post Mon Dec 09, 2013 11:08 pm
bss325i wrote:I would not be using that black schutz.
yea im hearing good and bad things bout it, and i saw on a thread recently about how annoying it was to get off when there was rust underneath! 8O
once waxoiled wouldnt it be good over the top of it as another barrier?
Post Mon Dec 09, 2013 11:56 pm
You generally put the Schutz on prior to applying Waxoyl! :wink:
Cypriotgeeza
Post Tue Dec 10, 2013 12:13 am
Speedtouch wrote:You generally put the Schutz on prior to applying Waxoyl! :wink:
Oh isit :o:
We used to underseal the japanese imports on my previous job and that used to protect them so well! Ive never used waxoyl before :o:
Obviously cant compare a 23yr old E30 with a fresh jap import but i was thinking of the same result.. lol
Post Tue Dec 10, 2013 12:29 am
Well, the Schutz is a hard surface protective covering, whereas Waxoyl is as the name suggests, an oily wax, that remains fairly 'liquid'.
If you were to put the Waxoyl on first, the Schutz would probably all peel off within a matter of days, like applying paint to a greasy surface.
Cypriotgeeza
Post Tue Dec 10, 2013 5:43 am
Makes sense i guess.. so the general opinion is that "schutz is shite" ? lol
polsta
Post Tue Dec 10, 2013 12:40 pm
shultz is ok for the right use, with all thse sort of products you have to ensure you use each one properly, remember waxoyl is a temporay/wear out sort of product that you renew when needed,and dont put anything on top of it
the fertan- before goign gun ho, give it a little test to see how it works, on something rusty like a really old rusty tool or something, brush a small bit on to the rust and leave it 24 hrs
Post Tue Dec 10, 2013 1:01 pm
Indeed. Schutz is normally used on 'high impact' areas, such as sills and inner wheelarches, as it gives good stonechip protection.
Cypriotgeeza
Post Tue Dec 10, 2013 1:26 pm
Yea that was the areas i was planning to use it..yea im going to do a bit of experimenting with the fertan as ive never used it before too :D
There will be plenty of pics of the progress so watch this space!
polsta
Post Tue Dec 10, 2013 2:49 pm
im not an expert/too familiar with shultz, but on the inner wheel arches- its a polyeurethane sealant, which ideally is what you want to use if touching up in them areas
Post Tue Dec 10, 2013 6:09 pm
polsta wrote:im not an expert/too familiar with shultz, but on the inner wheel arches- its a polyeurethane sealant, which ideally is what you want to use if touching up in them areas
This.
That black schutz shite is for spraying over welded on patches on old scrappers to get them through an MOT.
Think Ford Transit sills!
A polyurethane "stone chip" sealant is what you need. 3M do it and so do BMW.
Post Tue Dec 10, 2013 7:09 pm
This.
Do you have a link to the 3m stuff?
Cypriotgeeza
Post Tue Dec 10, 2013 11:00 pm
This.
Ill ask about this stuff tomorrow at work..Cheers guys :thumb:
Cypriotgeeza
Post Sat Dec 14, 2013 11:36 pm
Small update
Got in from work and jumped straight onto applying some fertan to the little scabs on the inside of the car..then it started raining again :-x so quickly covered her up and retreated to my garage..
Bought a metal polishing set the other day so i set to work to see how good it was on my 'neglected' borbet a's..
heres some before n afters 8O
Getting there...
leeparkes
Post Sat Dec 14, 2013 11:43 pm
What polish you using?
Cypriotgeeza
Post Sat Dec 14, 2013 11:47 pm
leeparkes wrote:What polish you using?
Autosol, i use it for my exhaust aswell f***in brilliant stuff for the price!
leeparkes
Post Sun Dec 15, 2013 12:05 am
When i had my Mahles they were bare polished alloy and Autosol got them shiney but didnt take long to go dull and pitted again.
I liked using meguiars all metal polish, brings em up like a mirror without much effort and has anti corrosive shizzle so the shine lasts.
Im sure there's other products out there like poorboys etc but i liked that stuff, get it from Halfords for under £10
Cypriotgeeza
Post Sun Dec 15, 2013 12:12 am
leeparkes wrote:When i had my Mahles they were bare polished alloy and Autosol got them shiney but didnt take long to go dull and pitted again.
Nice one man thanx for the tip! :D I was just experimenting just to see how it would look, no point getting them all shiny atm as its only going to go dull by the time the summer comes back around init lol
