Old skool Hartge 27 e30 325i Sport
That has a cracked dash!
So what the latest in dash repair? Or shall I not bother and get a replacement and do that annoying rattle on the heater on 1&2 at the same time? Even something to make it look better until i do it would be cool.
What do you rek?
p.s. I will gets some pics tomorrow
What do you rek?
suedenim
If the believe the noise is from the fan, no need to remove the dash as it's accessed from the bulkhead in the engine bay.
I would look for a good dash.
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
1001000010
Thanks, that will make life eaiser with the fan. Removing the dash, how much of a mission is that? Will i need to remove everything for the dash first? any links to a good how to?
Kaz
Kaz
polsta
google it theres a brilliant guide with lots of pics, its not too hard and go slowly and surely you can do it- take lots of pics as you go (for reference for re-fitting) and put all the fittings in little tubs etc, andf buy all new bulbs for the dash lights etc whilst your doing it
but more importantly, as its probably never been out- a good chance to check and repair the bulkhead areas for rust etc , around the gromets and corners, whilst your there if you haver the space/time, strip the carpet out, give the floor and al the wiring a good check over- remove and re-wrap the loom with fabric tape etc etc
suedenim
There's a download in the wiki 'changing your dash', it's for a LHD but looks relevant. It's worth checking the wiki for any queries, along with the search function, these are old cars and most things have been documented already.
Good luck
Good luck
1001000010
Wicked thank you....... we talking a couple hours each way ?
Kaz
Kaz
Ok - that looks involved and a second pair of hands and a roof over the car would be useful.
I am working in the open, might we worth trying to get some cover before i try that one.
Kaz
Kaz
polsta
depends what you find as to "each way" , most people would be pretty certain there will be rust issues found once its out, weather major or small needing attention, maybe some wiring issues too, i certainly wouldnt be planning to remove and put a new one straight in
also buy a new foam heater gasket from bmw to have ready, that sits between the heater and dash
1001000010
What I mean is how much time to remove the dash and later to re-install it again.s
Kaz
Kaz
polsta
dash out- hour or so, its not actualy that hard to remove or put it- but more time consuming is making sure everything is right and in place properly when putting back in and lots more fiddling about than removing, someone fluent in it could do an in-out swapm in a day, but for putting it back in if youve never done it, id allow a couple of days to get it done properly from start to finish including all the tinkering with bits and any problems encountered
1st thing to do, is remove your dash and have a good look at it all
when i put my dash back in, it took a good few days, but then that was also sorting out the look and re-wrapping it in fabric tape and getting everything in properly, bit of fiddling with the wiring and trim behind the glove box etc
so really it all depends what you encounter/see once the dash is removed and condition of the bulkhead and around the big rubber grommet (always rusts) and hopefuly no horrors
polsta
looking at the pics of your car in the other thread, id say that you 100% definatly want to remove the dash and carpets, and youl be in for a whole heap of fun/time/money before it comes to a time of re fitting it all...
car looks like it needs a full restoration and wil have lots of rust issues to be found
1001000010
I agree, thats why i am thinking about stripping what i need for my Hartge 27 out of this one and then sell the bits, quite gutted about it really.
Engine has very low miles since the rebuild as a 2.6 as does the LSD and Hartge suspension kit.
I need a Dash, rear exhaust box (which are no longer available) and a few silly bits to fix up a few issues on the H27 and I have all of the bits in my H26. which is starting to look like alot more hours that at first what i thought (famous last words)
What do you think
Kaz
What do you think
Kaz
Be sure to drink your Ovaltine, 578:
010000100110010100100000011100110111010101110010011001
010010000001110100011011110010000001100100011100100110
100101101110011010110010000001111001011011110111010101
110010001000000100111101110110011000010110110001110100
01101001011011100110010100101110
http://www.roubaixinteractive.com/PlayG ... o_Text.asp
Grrrmachine
- E30 Zone Wiki / Team Member
I think if it's a real Harte with provenance then it doesn't matter how much time it takes; get it fixed. E30s are already appreciating assets and a Hartge with a papertrail will be even more so. For the sake of an afternoon and a dashboard, plus an exhaust ordered from Germany, you could have a really rare car on your hands.
Not seen any pics of the shell yet so can't comment on that.
polsta
links to car below, looks like it needs a lot of work and on a strip down would reveal a whole host of issues, looks like a full resto job in waiting, and from what your posting/saying it doesnt sound like your head heart and wallet would be in for it, sadly , as above they are rare cars abeit a 4 door, but still, would be nice to see it saved
http://s987.photobucket.com/user/lumpyE ... ort=3&o=11
http://s987.photobucket.com/user/lumpyE ... ort=3&o=10
A Hartge H26 doesn't have a 2.6 engine.1001000010 wrote:I agree, thats why i am thinking about stripping what i need for my Hartge 27 out of this one and then sell the bits, quite gutted about it really.
Grrrmachine wrote:I think if it's a real Harte with provenance then it doesn't matter how much time it takes; get it fixed. E30s are already appreciating assets and a Hartge with a papertrail will be even more so. For the sake of an afternoon and a dashboard, plus an exhaust ordered from Germany, you could have a really rare car on your hands.
It's a foooked auto quattroporte. It is scrap.
1001000010
pmsl i hope you didnt go there trying to find out what my username meant. just pounded the 2 numbers until it appeared. got tired of reading "sorry that username has been taken"Speedtouch wrote:Be sure to drink your Ovaltine, 578:
I agree i want to do it up, but everyone around me is telling me dump it finish up the 27 with some of the bits sell the good bits and pass the usual stuff to a re seller.Grrrmachine wrote:I think if it's a real Harte with provenance then it doesn't matter how much time it takes; get it fixed. E30s are already appreciating assets and a Hartge with a papertrail will be even more so. For the sake of an afternoon and a dashboard, plus an exhaust ordered from Germany, you could have a really rare car on your hands.
The dash board job is for the 27 i am talking about the 26 i also have. Follow the link to see it, scroll left for more pics. Its real and Germany do not have any rear boxes and nor do Birds. these cars was built in very small numbers.
The H27 is just engine full exhaust system (inc headers) and ECU plus some bling parts cam cover, steering wheel. The 26 was engine exhaust no headers ECU Hartge suspension kit discs and possibly calipers and a really trick looking rear box (i think)- i need to check the paperwork to confirm some of that.polsta wrote:links to car below, looks like it needs a lot of work and on a strip down would reveal a whole host of issues, looks like a full resto job in waiting, and from what your posting/saying it doesnt sound like your head heart and wallet would be in for it, sadly , as above they are rare cars abeit a 4 door, but still, would be nice to see it saved
I see what they mean i would have one trick Hartge by combining the parts, although the M-tech suspension is eaiser on the lower spine
lol that seems to be the general opinion......... broom itpacerpete wrote:Grrrmachine wrote:I think if it's a real Harte with provenance then it doesn't matter how much time it takes; get it fixed. E30s are already appreciating assets and a Hartge with a papertrail will be even more so. For the sake of an afternoon and a dashboard, plus an exhaust ordered from Germany, you could have a really rare car on your hands.
Kaz
1001000010
Getting back to the H27,
Decided to hold on the dash for better weather - its p!$$ing almost every day.
I found a Hartge suspension kit that was taken off a demo H26 to test some experimental suspension. That experimental suspension got sold with the H26 and the Original Hartge suspension got boxed and put away. They had only a few thousand miles on them.
Managed to get them for a good price and hopefully by next week it will be all done.
Currently
http://s987.photobucket.com/user/lumpyE ... sort=3&o=0
Kaz
Currently
Kaz
1001000010
New rims with Titanium bolts on reconditioned inners and centres.
Next mission get them to 4 stud.
Kaz
BenHar
Kaz
1001000010
Thanks for that - where am i going wrong?
steve_k
IIRC the early one's did, same as an early c2 2.5 (like Felix's old one).bss325i wrote:A Hartge H26 doesn't have a 2.6 engine.1001000010 wrote:I agree, thats why i am thinking about stripping what i need for my Hartge 27 out of this one and then sell the bits, quite gutted about it really.
Grrrmachine
The link to your pics needs to end with .jpg before the [ img] tags. You linked to the page where the images are, not the actual images.
1001000010
I knew that was coming, i meant the picssteve_k wrote:IIRC the early one's did, same as an early c2 2.5 (like Felix's old one).bss325i wrote:A Hartge H26 doesn't have a 2.6 engine.1001000010 wrote:I agree, thats why i am thinking about stripping what i need for my Hartge 27 out of this one and then sell the bits, quite gutted about it really.
Thank you GrrrGrrrmachine wrote:The link to your pics needs to end with .jpg before the [ img] tags. You linked to the page where the images are, not the actual images.
Kaz
the H26 donk was simply a 325i engine with a spiky cam, a bit of port work and an ECU,steve_k wrote:IIRC the early one's did, same as an early c2 2.5 (like Felix's old one).bss325i wrote:A Hartge H26 doesn't have a 2.6 engine.1001000010 wrote:I agree, thats why i am thinking about stripping what i need for my Hartge 27 out of this one and then sell the bits, quite gutted about it really.
there is no 2.6 M20 !!
Steve K is right, the 323i based H26 had a 2554cc engine using an eta block like just like the 323i based Alpina C2 2.5.e30topless wrote:the H26 donk was simply a 325i engine with a spiky cam, a bit of port work and an ECU,steve_k wrote:IIRC the early one's did, same as an early c2 2.5 (like Felix's old one).bss325i wrote: A Hartge H26 doesn't have a 2.6 engine.
All the 325i based H26's were as topless describes but to add they used a special headgasket to up the compression ratio.
As the gasket is NLA, they now will skim the head to up the compression ratio.
1001000010
1001000010
Follow me for H26 debate,
http://www.e30zone.net/modules.php?name ... c&t=245372
leaving this thread to wonder what 17inch rims will do to my H27's ride
Kaz
Kaz
steve_k
Thank you Barry
Also, there IS a 2.6 m20, it's sat in my sports engine bay
1001000010
Trying to figure out which ECU i have, but the stickers on mine don't seem to match up with the general ones. I got some pics of the ECU only 2 sides had any detail.
http://s987.photobucket.com/user/lumpyE ... =3&o=3.jpg
http://s987.photobucket.com/user/lumpyE ... =3&o=4.jpg
Also trying to figure out which injectors i have in there, they are blue on top
http://s987.photobucket.com/user/lumpyE ... =3&o=1.jpg
http://s987.photobucket.com/user/lumpyE ... =3&o=0.jpg
Reason is i am looking to do a AFM to MAF upgrade and need to know these two details.
Kaz
Kaz
BenHar
1001000010 wrote:Trying to figure out which ECU i have, but the stickers on mine don't seem to match up with the general ones. I got some pics of the ECU only 2 sides had any detail.
Kaz
That 'ECU' is the ABS control unit! The engine ECU is located under the dashboard on the driver's side - remove the trim panel below the steering column using a coin and look up to find a silver box with 'Motronic' written on it; it should have a label with a part number, e.g. 0 261 200 173.
lol i just figured that out - sweet thanks Maurice
And the injectors are stock
Kaz
Kaz
