M20B28 build
reggid
Post Fri Jul 26, 2013 6:29 am
a higher comp m20 engine likes NGK BPR6ES
original stack height is 206.7 mm (throw 37.5 mm +rod 135 mm+piston comp height 34.2 mm)
original deck is 206.2 mm so nominally the piston sits 0.5 mm above the deck AFAIK
a 4.5 mm longer throw (i.e. 9 mm longer stroke) with 84 mm crank and 5 mm shorter rod puts piston down 0.5 mm from stock which is much the same as level with top of block.
E30 325is with M20B31
aceifty
Post Fri Jul 26, 2013 8:45 am
Ill get pictures up later showing the pistons meeting at the top
gromgsxr
Post Fri Jul 26, 2013 9:53 am
so is it best practice to remove the 0.5mm of the block or not?
reggid
Post Fri Jul 26, 2013 11:42 am
ideally you want between 1.00mm and 1.25mm between the piston 20* angled squish band and the corresponding band on the head to give the proper chamber motion. Then there is piston to valve clearance
its best to measure this stuff as you wont really know if the block or head have ever been skimmed.
i think it is pretty hard to find the proper 1.75mm head gaskets these days.
aceifty
Post Thu Aug 01, 2013 9:36 pm
ill be doing a squish test to check if i have got the valve clearance as the head has been skimmed but don't know how many times.
had a few hiccups near the end, just noticed that the sump has a small crack but does not leak. (not going to chance it):x
i had forgot to order the crank sensor, oil sensor and the temp sensor :mad: (but all ordered today morning) my engine hoist is on its way to.:cry:
if everything else goes good the engine might be in on Sunday. :D
aceifty
Post Sun Aug 18, 2013 6:45 pm
a lot has been done after my last post.
the squish test.
To check the squish profiling and valve/piston clearance, a bit of plasticine was used. Done it on three pistons (both end ones and one from the middle), to make sure the head and block are all even and not on a funny angle.
Usual process put the plasticine on the valve cuts on piston and the angled edge for the squish band. Put the timing on and give it a full revolution.
Know I know the best way would be to use proper tools to check the thickness, like a micrometer, but im building the engine in my kitchen :P im not an engineer im a postman don’t have those things lol. Made do with using a filler gage to check the thickness. Pictures show how this was done.
All the clearances were spot on and all even.
engine is in and up running car flew through it M.O.T :D
aceifty
Post Tue Aug 20, 2013 12:06 pm
after doing the squish test and everything being perfect i had started to put everything that needs to go on he block on,
the bottom cover went on and the sprocket.
the water pump
now the new tensioner
for now im done on this side
aceifty
Post Tue Aug 20, 2013 12:14 pm
bolted on the new oil pump and got hold of another sump :D
aceifty
Post Tue Aug 20, 2013 12:20 pm
now the gearbox side.
the oil seal went on first, ( cant seem to find the pic) :(
the gearbox side started to get to gether.
the new gearbox mount bushes
aceifty
Post Tue Aug 20, 2013 12:22 pm
the new engine bushes went on left and right
aceifty
Post Tue Aug 20, 2013 12:29 pm
the gearbox got bolted to the block and all the gear selector bushes got changed and a z3 shiftier put on (cant seem to find the pictures) :x
the chrome engine mounts went on
block and gear box are ready to go in the car
happy days it is in
aceifty
Post Tue Aug 20, 2013 12:35 pm
i had decided to place the exhaust manifold with the down pips in before putting the head on.
injector rail got put back together
the z3 shiftier
aceifty
Post Tue Aug 20, 2013 12:40 pm
now im ready for the heat to go on.
first i had placed to new gasket on
the head
the rocker cover will be getting changed once iv completed painting the other one.
and the timing done
aceifty
Post Tue Aug 20, 2013 12:43 pm
the inlet manifold and the rocker cover
rocker cover still needs finishing
aceifty
Post Tue Aug 20, 2013 12:51 pm
first etempt to start it
would not start as the car ha stale fuel in by the time i got some fresh fuel in it got dark but got the car to start, and it sounded like a tank as the tappets needed doing and the exhaust tightening
aceifty
Post Tue Aug 20, 2013 12:58 pm
the next day i had started the car up and left it running for about an hour then drained the oil. next oil change will be in 100 mils
aceifty
Post Tue Aug 20, 2013 1:03 pm
the car is running a bit rough and lumpy as im still waiting for the Miller maf with the W.A.R chip, which will sort it out.
the car needs a good map, will be doing it once io get the maf and war chip.
apart from that the car runs much better that the first start up. ill try to get a vid up later.
aceifty
Post Thu Aug 22, 2013 7:54 pm
received the custom charge today for the miller maf + the war chip which was only £51.30 because they had put a very low value o the deceleration.
should be getting it tomorrow :D
been waiting just over a month for it, its been at the customs for about 3 weeks :mad:
Rallyprep_UK
formerly Driftnething
Post Tue Aug 27, 2013 7:21 pm
Nice build :-)
I am doing a similar one myself - currently gathering parts...
Will
Racing is living, everything else is just waiting...
http://www.rallyprep.co.uk
aceifty
Post Wed Sep 04, 2013 5:49 pm
just a update
so-far the car has now covered 182 miles since iv got it on the road. drives a lot better and pulls very good.
yesterday i had installed the miller maf plus the war chip and it has made a big difference to the way it drives. difference in a good way as before the miller stuff it was very lumpy.
as soon as iv got the engine bedded in ill be getting a dyno.
Post Wed Sep 04, 2013 7:19 pm
Rings will be bedded in by now, so get it on the dyno :D
Rallyprep_UK
Post Wed Sep 04, 2013 9:55 pm
Haha :-D
E30machine
Post Wed Sep 11, 2013 4:00 pm
Saw you driving this the other day looks good
It's Azams mate with the tech 1 btw
ULTIMATE DRIVING MACHINE
aceifty
Post Wed Sep 11, 2013 7:54 pm
E30machine wrote:Saw you driving this the other day looks good
thanks bro, need to do a bit more work to it.
how yours running, looks good
jimbom30cab
Tech 1 freak
Post Wed Sep 11, 2013 7:58 pm
so would you say the millar maf and war chip makes a good difference to the way the engine runs and performs ?
aceifty
Post Thu Sep 12, 2013 3:37 pm
jimbom30cab wrote:so would you say the millar maf and war chip makes a good difference to the way the engine runs and performs ?
the map on the chip still needs a bit of a tune, also at the moment iv got a chav cone filter which i want to remove and have the standard air box.
apart from that it runs much better that before, fuel is much better and now i can drive the car in lower revs.
E30machine
Post Fri Sep 13, 2013 1:31 am
Yeah mine is good but will be coming off the road in January as it will need some restoration work .
diletant
Post Tue Sep 17, 2013 3:11 pm
Very nice work :bmw:
aceifty
Post Thu Nov 07, 2013 12:23 pm
just a small update, still not got it on a dyno, but raced the car with my r32 skyline and the skyline could not shake me off i also ended up racing a 2013 audi a6 on my way home and it could not get in front of me, suddenly a seen blue lights the a6 i was racing was undercover cops and they where surprised that they couldn't get in front of me. it was nice of the cops to let me go and not do me.
pictures will be added soon of the miler maf conversion.
Sanchez
Post Thu Nov 07, 2013 12:50 pm
aceifty wrote:just a small update, still not got it on a dyno, but raced the car with my r32 skyline and the skyline could not shake me off i also ended up racing a 2013 audi a6 on my way home and it could not get in front of me, suddenly a seen blue lights the a6 i was racing was undercover cops and they where surprised that they couldn't get in front of me. it was nice of the cops to let me go and not do me.
lol.
aceifty
Post Thu Nov 07, 2013 2:47 pm
lol.
why, is it because i raced the old bill
Hedley48
Post Tue Nov 26, 2013 7:07 pm
doing the same to mine soon ive got the crank, rods, low compression pistons and all the seals and gaskets but still need a lot as im converting to a manual box and putting a turbo on,ive never done anything like this before so this thread is very handy but is there anything i should watch out for like more difficult parts of the build, and also did you use a torque wrench or just make sure everythings tight, cheers dan :)
aceifty
Post Tue Nov 26, 2013 7:49 pm
Hedley48 wrote:doing the same to mine soon ive got the crank, rods, low compression pistons and all the seals and gaskets but still need a lot as im converting to a manual box and putting a turbo on,ive never done anything like this before so this thread is very handy but is there anything i should watch out for like more difficult parts of the build, and also did you use a torque wrench or just make sure everythings tight, cheers dan :)
everything has be torqued up using a torque wrench.
this is the second m20b28 that i have done, it is a very easy engine to work on. you might as well get new piston rings and the bottom end bearings, also if your going to put on a turbo ill be changing the rocker for some heavy duty ones. (got mine from IE) if you have done a head job before then the bottom end is easy. be careful when putting the new piston rings on as they can break very easy.
if im wright you might need to weld water ports on the head and the bottom block if you are going the turbo way
the most important thing is to check everything properly, then then check again and again. do a squish test.
if you need any help just get in touch and ill help out in what ever way i can
Hedley48
Post Tue Nov 26, 2013 7:53 pm
nice one i have done heads before in college lol, how much were the rockers and what torque does everything need to be, already got rings and theyre on the pistons so no worries there :D
aceifty
Post Thu Nov 28, 2013 7:05 pm
Hedley48 wrote:nice one i have done heads before in college lol, how much were the rockers and what torque does everything need to be, already got rings and theyre on the pistons so no worries there :D
rockers cost about £600 inc custom charge and delivery.
pm'd
